[gdal-dev] Re: gdaladdo creates very large files in 1.8 but not
trunk
Even Rouault
even.rouault at mines-paris.org
Thu Apr 14 14:34:54 EDT 2011
> You can check which kind of overview file you really have with gdalinfo if
> you first rename the .ovr file to something.tif. Gdalinfo then shows the
> compression method used and sizes of overviews. No need to do guessing
> with OpenEV.
You don't even need to rename the file. GDAL doesn't care about the extension
to recognized TIFF files
> -Jukka Rahkonen-
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
