[gdal-dev] LAS format driver for OGR?
Stefan Keller
sfkeller at gmail.com
Sun Apr 17 06:56:39 EDT 2011
Mateusz,
Thanks for your replies (also to Even). Your answered:
> Some time ago I have written a tool to dump LAS data to virtually
> any OGR dataset:
> http://liblas.org/utilities/las2ogr.html
I'll have a look at http://liblas.org/utilities/las2ogr.html
My goal is to import it in PostGIS and a Java program.
>> Scanning this mailing list I could not find an answer except to use
>> LAStools. But since LAS is essentially just a simple vector point data
> Considering point clouds in terms of (only) a simple vector point data is
> a misunderstanding.
You're right. I should have written:
LAS is essentially vector point data plus a (more or less?) fixed
number of properties like color.
Yours, S.
2011/4/17 Mateusz Loskot <mateusz at loskot.net>:
> Stefan Keller wrote:
>> I tried to read LIDAR data in LAS format from LAStools
>> (http://www.cs.unc.edu/~isenburg/lastools/ ) but without success using
>> gdalinfo and ogrinfo. Even the Python LAS->shapefile converter
>> (http://code.google.com/p/pylas/ ) failed ("TypeError...").
> any OGR dataset:
> a misunderstanding.
> Best regards,
> Mateusz Loskot
> http://mateusz.loskot.net
