[gdal-dev] Problem with GDALDatasetRasterIO.cs and ECW files
Francisco José Reyes Peralta
gistdt08 at hotmail.es
Tue Apr 19 10:41:54 EDT 2011
Sorry, tomorrow in the morning pass you the entire code and the value of pixelFormat__1 because the code is in my office.
Thanks for your reply.
Francisco J.
Date: Tue, 19 Apr 2011 16:10:27 +0200
Subject: Re: [gdal-dev] Problem with GDALDatasetRasterIO.cs and ECW files
To: gistdt08 at hotmail.es
CC: gdal-dev at lists.osgeo.org
Not sure what is the actual value of 'pixelFormat__1' in your program.
Best regards,
Tamas
2011/4/19 Francisco José Reyes Peralta <gistdt08 at hotmail.es>
The parameter is not valid is the error that I get.I use an adaptation of the source .cs code in VB.NET.
Here is part of the code:
Dim pixelFormat As PixelFormat Dim dataType As DataType
Dim pixelSpace As Integer
If isIndexed Then
pixelFormat = PixelFormat.Format8bppIndexed
dataType = DataType.GDT_Byte
pixelSpace = 1
Else
If channelCount = 1 Then
If channelSize > 8 Then
pixelFormat = PixelFormat.Format16bppGrayScale
dataType = DataType.GDT_Int16
pixelSpace = 2
Else
pixelFormat = PixelFormat.Format24bppRgb
channelCount = 3
pixelSpace = 3
End If
Else
If hasAlpha Then
pixelFormat = PixelFormat.Format64bppArgb
dataType = DataType.GDT_UInt16
pixelSpace = 8
Else
pixelFormat = PixelFormat.Format32bppArgb
pixelSpace = 4
End If
channelCount = 4
Else
pixelFormat = PixelFormat.Format48bppRgb
pixelSpace = 6
Else
pixelSpace = 3
End If
channelCount = 3
End If
End If
End If
And the Error is in the following line:
Dim bitmap As New Bitmap(imageWidth, imageHeight, pixelFormat__1)
Is possible to read the dataset and write to a bitmap or picturebox without save as file?
Francisco J.
> Dear friends, I'm vieweing the *GDALDatasetRasterIO.cs* from the Csharp
> samples of GDAL and I'm getting an error in the following line *Bitmap
> bitmap = new Bitmap(imageWidth, imageHeight, pixelFormat);* In the *
> pixelFormat* argument.
What is the error message specifically?
Best regards,
Tamas
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20110419/cc8baab2/attachment-0001.html
gdal-dev mailing list
http://lists.osgeo.org/mailman/listinfo/gdal-dev
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20110419/355f992c/attachment.html
