[gdal-dev] How load in memory bitmap without save a GDAL image local file?
Francisco José Reyes Peralta gistdt08 at hotmail.es
Tue Apr 19 15:27:52 EDT 2011
Dear friends,
In the csharp sample files located in the path gdal\swig\csharp\apps\ as GDARead.cs, GDALReadDirect.cs and so much, the developer always store in a local file.
Is possible to save in a Bitmap without need of a physical file location? It is because if you need to load an up to 2GB file, how can we do it?
Thanks.Francisco J.
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20110419/32fbf2ab/attachment.html
