[gdal-dev] Problem with GDALDatasetRasterIO.cs and ECW files
Chaitanya kumar CH
chaitanya.ch at gmail.com
Wed Apr 20 03:24:36 EDT 2011
Francisco,
I can't tell why you got the "Parameter is invalid" error. Perhaps you
should try some VB.net forums.
2011/4/20 Francisco José Reyes Peralta <gistdt08 at hotmail.es>
> The value of pixelFormat is *Format24bppRGB*
> **Here is the code that I use, but I cannot load into a Bitmap. Maybe I
> don't undesrtand really how to translate the datasource into a bitmap.
> Public Sub GuardarBitmap(ByRef bmp As Bitmap, ds As Dataset, xOff As
> Integer, yOff As Integer, width As Integer, height As Integer, _
> imageWidth As Integer, imageHeight As Integer)
> Dim bands As Integer() = New Integer(3) {1, 1, 1, 1}
> Dim alpha As Boolean = False
> Dim index As Boolean = False
> Dim numChannels As Integer = 1
> Dim channelSize As Integer = 8
> Dim ctable As ColorTable = Nothing
> For i As Integer = 0 To ds.RasterCount - 1
> Dim band As Band = ds.GetRasterBand(i + 1)
> If Gdal.GetDataTypeSize(band.DataType) > 8 Then
> channelSize = 16
> End If
> Select Case band.GetRasterColorInterpretation()
> Case ColorInterp.GCI_AlphaBand
> numChannels = 4
> alpha = True
> bands(3) = i + 1
> Exit Select
> Case ColorInterp.GCI_BlueBand
> If numChannels < 3 Then
> numChannels = 3
> End If
> bands(0) = i + 1
> Exit Select
> Case ColorInterp.GCI_RedBand
> numChannels = 3
> End If
> bands(2) = i + 1
> Exit Select
> Case ColorInterp.GCI_GreenBand
> numChannels = 3
> End If
> bands(1) = i + 1
> Exit Select
> Case ColorInterp.GCI_PaletteIndex
> ctable = band.GetRasterColorTable()
> index = True
> bands(0) = i + 1
> Exit Select
> Case ColorInterp.GCI_GrayIndex
> index = True
> bands(0) = i + 1
> Exit Select
> Case Else
> If i < 4 AndAlso bands(i) = 0 Then
> If numChannels < i Then
> numChannels = i
> End If
> bands(i) = i + 1
> End If
> Exit Select
> End Select
> Next
> Dim pixelFormat__1 As PixelFormat
> Dim dataType__2 As DataType
> Dim pixelSpace As Integer
> If index Then
> pixelFormat__1 = PixelFormat.Format8bppIndexed
> dataType__2 = DataType.GDT_Byte
> pixelSpace = 1
> Else
> If numChannels = 1 Then
> If channelSize > 8 Then
> pixelFormat__1 = PixelFormat.Format16bppGrayScale
> dataType__2 = DataType.GDT_Int16
> pixelSpace = 2
> Else
> pixelFormat__1 = PixelFormat.Format24bppRgb
> numChannels = 3
> pixelSpace = 3
> End If
> Else
> If alpha Then
> pixelFormat__1 = PixelFormat.Format64bppArgb
> dataType__2 = DataType.GDT_UInt16
> pixelSpace = 8
> Else
> pixelFormat__1 = PixelFormat.Format32bppArgb
> pixelSpace = 4
> End If
> numChannels = 4
> Else
> pixelFormat__1 = PixelFormat.Format48bppRgb
> pixelSpace = 6
> Else
> pixelSpace = 3
> End If
> numChannels = 3
> End If
> End If
> End If
> Dim bitmap As New Bitmap(imageWidth, imageHeight, pixelFormat__1)
> If index Then
> If ctable IsNot Nothing Then
> Dim iCol As Integer = ctable.GetCount()
> Dim pal As ColorPalette = bitmap.Palette
> For i As Integer = 0 To iCol - 1
> Dim ce As ColorEntry = ctable.GetColorEntry(i)
> pal.Entries(i) = Color.FromArgb(ce.c4, ce.c1, ce.c2,
> ce.c3)
> Next
> bitmap.Palette = pal
> Else
> For i As Integer = 0 To 255
> pal.Entries(i) = Color.FromArgb(255, i, i, i)
> Next
> End If
> End If
> Dim bitmapData As BitmapData = bitmap.LockBits(New Rectangle(0, 0,
> imageWidth, imageHeight), ImageLockMode.ReadWrite, pixelFormat__1)
> Try
> Dim strideBMD As Integer = bitmapData.Stride
> Dim buf As IntPtr = bitmapData.Scan0
> ds.ReadRaster(xOff, yOff, width, height, buf, imageWidth, _
> imageHeight, dataType__2, numChannels, bands, pixelSpace,
> strideBMD, _
> 1)
> Finally
> bitmap.UnlockBits(bitmapData)
> End Try
> bmp = bitmap
> End Sub
> Thanks in advanced.
> Francisco J.
> Date: Tue, 19 Apr 2011 16:10:27 +0200
> Subject: Re: [gdal-dev] Problem with GDALDatasetRasterIO.cs and ECW files
> From: szekerest at gmail.com
> To: gistdt08 at hotmail.es
> CC: gdal-dev at lists.osgeo.org
> Not sure what is the actual value of 'pixelFormat__1' in your program.
> Best regards,
> Tamas
> 2011/4/19 Francisco José Reyes Peralta <gistdt08 at hotmail.es>
> The parameter is not valid is the error that I get.
> I use an adaptation of the source .cs code in VB.NET.
> Here is part of the code:
> Dim pixelFormat As PixelFormat
> Dim dataType As DataType
> If isIndexed Then
> pixelFormat = PixelFormat.Format8bppIndexed
> dataType = DataType.GDT_Byte
> pixelSpace = 1
> Else
> If channelCount = 1 Then
> pixelFormat = PixelFormat.Format16bppGrayScale
> dataType = DataType.GDT_Int16
> pixelSpace = 2
> Else
> pixelFormat = PixelFormat.Format24bppRgb
> channelCount = 3
> pixelSpace = 3
> End If
> Else
> If hasAlpha Then
> pixelFormat = PixelFormat.Format64bppArgb
> dataType = DataType.GDT_UInt16
> pixelSpace = 8
> Else
> pixelFormat = PixelFormat.Format32bppArgb
> pixelSpace = 4
> End If
> channelCount = 4
> Else
> pixelFormat = PixelFormat.Format48bppRgb
> pixelSpace = 6
> Else
> pixelSpace = 3
> End If
> channelCount = 3
> End If
> End If
> End If
> And the Error is in the following line:
> Is possible to read the dataset and write to a bitmap or picturebox without save as file?
> Thanks for your reply.
> Francisco J.
> 2011/4/19 Francisco José Reyes Peralta <gistdt08 at hotmail.es <http://lists.osgeo.org/mailman/listinfo/gdal-dev>>
> >* Dear friends, I'm vieweing the *GDALDatasetRasterIO.cs* from the Csharp*>* samples of GDAL and I'm getting an error in the following line *Bitmap*>* bitmap = new Bitmap(imageWidth, imageHeight, pixelFormat);* In the **>* pixelFormat* argument.*>**
> Hi,
> What is the error message specifically?
> Best regards,
> Tamas
> -------------- next part --------------
> An HTML attachment was scrubbed...
> URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20110419/cc8baab2/attachment-0001.html
> gdal-dev mailing list
Best regards,
Chaitanya kumar CH.
/tʃaɪθənjə/ /kʊmɑr/
+91-9494447584
17.2416N 80.1426E
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20110420/7d82c9f4/attachment-0001.html
