[gdal-dev] Extract Extent or Bounding Box for a subset of
shapes for a shapefile
Luca Sigfrido Percich
sigfrido at tiscali.it
Fri Apr 22 10:14:46 EDT 2011
Hi Matthew,
Your question is interesting. ogrinfo -where seemed to be the answer,
but...
I tried ogrinfo with the -where "sql where" option with both MapInfo and
PostGIS layers. In your case it should be:
ogrinfo -ro -so -al -where "$WHERECLAUSE" "whole_shapefile.shp"
The returned extent is always the same, regardless of the presence or
composition of the -where clause, so it refers to the whole layer rather
than to the selected features.
(I'm using GDAL 1.9 dev)
Is this the expected behaviour of ogrinfo -where "..."? Or sould -where
affect the returned Extent too?
Thank you all
Sig
Il giorno ven, 22/04/2011 alle 08.22 -0500, Matthew Pettis ha scritto:
> Hi All,
> I think this is the right list for the question below, as I cannot
> find a different list that matches my question better.
> I'm using ogr2ogr and ogrinfo (v1.4), and I want to extract the extent
> from the result of a subsetting where argument. I have a solution
> here that works but I'm wondering if I'm missing some more obvious
> solution. In a bash script, I do the following (the core snippet
> only, as I took out the shebang and option-getting/setting code:)
> rm -rf /tmp/tmpshpfile.*
> ogr2ogr -where "$WHERECLAUSE" /tmp/tmpshpfile.shp "$FILE"
> ogrinfo -ro -so -al /tmp/tmpshpfile.shp | \
> grep Extent | \
> tr -d '[:alpha:]:() -' | \
> tr ',' ' '
> I can use it as follows:
> $ ./bbox.sh -f /path/to/shp/shp_counties.shp -w "COUNTY_NAME='Yellow
> Medicine'"
> 226206.484375 4934737.000000313007.250000 4979500.500000
> Where the argument to '-w' is put into the '$WHERECLAUSE' variable in
> the script.
> This works. As I wrote, though, am I missing something obvious in
> command-line switches to either of these programs that would simplify
> this so I wouldn't have to use this script? Or is there some other,
> better way of doing this? Also, is there a way to pipe the output of
> ogr2ogr on stdout directly to the stdin of ogrinfo?
> Thanks,
> Matt
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
