[gdal-dev] Polygonize from C# ?
Elijah Robison elijah at villagis.com
Fri Apr 22 15:05:02 EDT 2011
Hi Jay, you might want to review the following thread (Get extent from
rasters).  Based on a cursory read of his advice, I believe Trent offers
a solution that might accommodate your task:
http://lists.maptools.org/pipermail/fwtools/2010-October/001886.html
/Elijah
Jay Jennings wrote:
> Correct, we just need the footprint of the "good" (non-NODATA) area, which will often approximate a simple 4-point polygon with no holes.
> -----Original Message-----
> From: Elijah Robison [mailto:elijah at villagis.com]
> Sent: Friday, April 22, 2011 2:07 PM
> To: Jay Jennings
> Cc: gdal-dev at lists.osgeo.org
> Subject: Re: [gdal-dev] Polygonize from C# ?
> Jay, do you basically want a footprint shape of the useful data in the
> Sat images (say, without the collar), or is the problem more complex,
> where perhaps you have a mosaic of several images and, like swiss
> cheese, there are no-data holes within the image?
> It sounds to me like you just want a footprint of the collarless area;
> is this correct?
> /Elijah
> Jay Jennings wrote:
>> I see, thanks.  But since I have satellite images, this part of the doc is alarming: "...For non-thematic raster data (such as satellite images)
>> the result will essentially be one small polygon per pixel, and memory and output layer sizes will be substantial. The algorithm is primarily
>> intended for relatively simple thematic imagery, masks, and classification results".
>> I just want one polygon enclosing the non-zero pixels (or alternatively, enclosing the zero pixels, then I could do a geometric
>> difference).  Is there any way to trick the method into doing that, to maybe avoid the heavy resource needs ?
>> From: Even Rouault [mailto:even.rouault at mines-paris.org]
>> Sent: Friday, April 22, 2011 11:45 AM
>> To: Jay Jennings
>> Selon Jay Jennings <Jennings.Jay at geoeye.com>:
>> Generally, refering to the C/C++ doc is a good way of finding the info :
>> See http://gdal.org/gdal__alg_8h.html#3f522a9035d3512b5d414fb4752671b1
>>> Hi list,
>>> Can anyone point to any guidance or (preferably) examples on using
>>> GDAL.Polygonize() with C# bindings ?  I see what the interface is, but there
>>> are some unexplained parameters, e.g. "string[] options".
>>> My eventual goal is to open a raster and produce a WKT POLYGON string
>>> enclosing the "good" (non-NoData) area of the raster.  Thanks.
>>> Jay Jennings
>>> Senior Software Developer
>>> (NASDAQ: GEOY)
>>> jennings.jay at geoeye.com
>> gdal-dev mailing list
>> http://lists.osgeo.org/mailman/listinfo/gdal-dev
