[gdal-dev] GDAL and HRE
Even Rouault even.rouault at mines-paris.org
Tue Apr 26 13:48:33 EDT 2011
Le mardi 26 avril 2011 13:10:15, georgec_511 at yahoo.com a écrit :
> hello,
> I saw your message on osgeo-org with the subject line NGA High Resolution
> Elevation (HRE) data problem?
> did you ever get the HRE files parsed with GDAL?  I'm working on the same
> sort of thing and was just wondering?  I'm just starting out.
Do you refer to the HRE files in NITF format ? They are successfully read by
GDAL, but the samples available show a vertical flip. However GDAL
interpretation of georeferencing contained in the file seems correct, so either
the samples are incorrect, either there's a subtelty that GDAL doesn't
understand...
> my email is georgec_511 at yahoo.com
> Thanks,
> George
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
