[gdal-dev] geotiff conflict
MALIK Julien
julien.malik at c-s.fr
Tue Apr 26 15:39:21 EDT 2011
Quoting "Francesco P. Lovergine" <frankie at debian.org>:
> On Tue, Apr 26, 2011 at 07:55:00PM +0200, Even Rouault wrote:
>> > What can we do to help find a solution (what kind of modification to the
>> > gdal debian package would you agree to make to solve this issue) ?
>> I'm not sure the solution is really in the debian packaging...
>> There are indeed very few (safe and easy) options :
>> - build the GDAL package to link with system/external libtiff and
>> libgeotiff.
>> But then you loose bigtiff support
>> - or make libtiff 4.X the system libtiff version (as in debian experimental)
>> > Do you have pointers on those "versioned symbols" you were referring to ?
> Here we go:
> http://www.netfort.gr.jp/~dancer/column/libpkg-guide/libpkg-guide.html#id293268
> of course this is a possibile solution to avoid symbol collision among
> different libraries. It is not a os-independent solution even, so I would
> consider it to solve problems in Debian, not a general (upstream) solution.
> This is exactly what I'm going to provide in 1.8/experimental for next
> library transition.
Oh GREAT !
So I guess the issue will be closed soon. Very, very good news for us
OrfeoToolbox users.
Thanks so much for considering this !
This message was sent using IMP, the Internet Messaging Program.
