[gdal-dev] validate/clean geometry with OGR?
Elijah Robison
elijah at villagis.com
Wed Apr 27 10:36:17 EDT 2011
Hey devs, is anyone aware of an OGR approach to validate/clean
geometries, for instance, as they are being converted from SHP to
PostGRESql?
It's not uncommon to have a handful of invalid geometries (usually
self-intersecting polygons) in a parcel dataset, and it's impractical to
correct them manually. In most situations I use the "Clean Geometries"
function in ArcGIS, which does fix the problem. However this one
functionality is my main reason to retain Arc in my primary tool chain.
I've never found a scripting approach by trolling the search engines so
I thought I'd ask here.
Thanks, Elijah
