[gdal-dev] validate/clean geometry with OGR?
Brent Fraser
bfraser at geoanalytic.com
Wed Apr 27 11:03:03 EDT 2011
Elijah,
I've used GEOS Buffer function available via the OGR API
(http://www.gdal.org/ogr/classOGRGeometry.html) to clean polygons:
OGRGeometry *poTempGeometry = poGeometry->Buffer(0.0); // Let Geos fix
the problem.
Best Regards,
Brent Fraser
On 4/27/2011 8:36 AM, Elijah Robison wrote:
> Hey devs, is anyone aware of an OGR approach to validate/clean
> geometries, for instance, as they are being converted from SHP to
> PostGRESql?
> It's not uncommon to have a handful of invalid geometries (usually
> self-intersecting polygons) in a parcel dataset, and it's impractical
> to correct them manually. In most situations I use the "Clean
> Geometries" function in ArcGIS, which does fix the problem. However
> this one functionality is my main reason to retain Arc in my primary
> tool chain.
> I've never found a scripting approach by trolling the search engines
> so I thought I'd ask here.
> Thanks, Elijah
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
