[gdal-dev] Re: Mask and GEOTiff
Jamie Adams
jaadfoo at gmail.com
Thu Apr 28 12:53:48 EDT 2011
You could run gdal_polygonize on the mask geotiff and then use the output
vector with gdal_rasterize. That's the only way I can think of without
writing a python script to do the pixel comparisons.
Jamie
On Thu, Apr 28, 2011 at 2:30 AM, canduc17 <candini at meeo.it> wrote:
> I think gdal merge is the easier way.
> But with a command like this:
> gdal_merge.py -of GTiff -separate -o cropped.tif orig.tif mask.tif
> I obtainn a GEOTiff with two bands: the first is the original image and the
> second is the mask.
> This is not what I want.
> I would like to obtain a single band GEOTiff with visible only the pixels
> of
> original image filtered by the mask.
> Is that possible with a further passage or with another tool?
> http://osgeo-org.1803224.n2.nabble.com/Mask-and-GEOTiff-tp6312284p6312590.html
> Sent from the GDAL - Dev mailing list archive at Nabble.com.
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20110428/a7530d26/attachment.html
