[gdal-dev] nearblack troubles [SEC=UNCLASSIFIED]
Even Rouault
even.rouault at mines-paris.org
Thu Apr 28 13:14:28 EDT 2011
Le jeudi 28 avril 2011 17:49:48, Matt Wilkie a écrit :
> > Worked for me using the following:
> > #Change black to white
> > gdalbuildvrt -srcnodata 0 -vrtnodata 255 to-be-decollared.vrt
> > to-be-decollared.tif
> > #Run nearblack -white
> > nearblack -white -o decollared.tif to-be-decollared.vrt
> Luke, once again I thank you. :)
There's one thing you must be aware of with the above process. The
gdalbuildvrt step will replace all 0 values by 255, but band per band, to be
opposite to detecting the triplet (0,0,0). So this might alter colors that
have least one component to 0 inside the raster.
> matt wilkie
> Geomatics Analyst
> Information Management and Technology
> Yukon Department of Environment
> 10 Burns Road * Whitehorse, Yukon * Y1A 4Y9
> 867-667-8133 Tel * 867-393-7003 Fax
> http://environmentyukon.gov.yk.ca/geomatics/
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
