[gdal-dev] ogr2ogr midmif to tab format conversion
Zoltan Szecsei
zoltans at geograph.co.za
Fri Apr 29 08:25:38 EDT 2011
Hi All,
I am trying to convert a bunch of MapInfo MID-MIF files to MapInfo TAB
files, because GeoMedia 6.1 will not "connect" to MIDMIF files.
Using this script on Ubuntu 10.04, ogr2ogr from GDAL 1.8.0, released
2011/01/12
for m in `ls *.mif` ; do n=`echo $m | awk -F . ' { print $1".tab" } ' `
; echo "******************** Starting $m" ; ogr2ogr -F "MapInfo File" $n
$m ; done
(Basically: ogr2ogr -F "MapInfo File" boundaries.tab boundaries.mif )
When I load the resulting .TAB, .ID, .MAP and .DAT files into GeoMedia,
I get coarse boxes and diagonal lines, albeit in the correct LatLong region.
When I use a very old "imutgui" from an old MapInfo to convert the same
MID MIFs to SHAPE, I can (correctly) load the SHAPEs into GeoMedia.
I cannot use the SHAPEfile route as the field names are truncated when
converting from MIDMIF to SHAPE.
Any idea why the TAB route messes up the geometries?
TIA,
Zoltan
Zoltan Szecsei PrGISc [PGP0031]
Geograph (Pty) Ltd.
P.O. Box 7, Muizenberg 7950, South Africa.
65 Main Road, Muizenberg 7945
Western Cape, South Africa.
34° 6'16.35"S 18°28'5.62"E
Tel: +27-21-7884897 Mobile: +27-83-6004028
Fax: +27-86-6115323 www.geograph.co.za
No virus found in this message.
Checked by AVG - www.avg.com
Version: 10.0.1209 / Virus Database: 1500/3603 - Release Date: 04/28/11
