[gdal-dev] .NET and OGR writing to stream
Maksim Sestic max at geoinova.com
Wed Aug 3 06:52:17 EDT 2011
Hi Tamas,
I don't know how to apply the same principle onto OGR drivers (not GDAL).
I'm trying to create GML structure in memory using OGR driver, then handle
resulting XML string further. Don't want to write dataset to a file, then
read the file back to a string.
Regards,
Maksim Sestic
  _____
From: Tamas Szekeres [mailto:szekerest at gmail.com]
Sent: Monday, August 01, 2011 13:05
To: Maksim Sestic
Cc: gdal-dev at lists.osgeo.org
Subject: Re: [gdal-dev] .NET and OGR writing to stream
Maksim,
You can refer to the example
http://trac.osgeo.org/gdal/browser/trunk/gdal/swig/csharp/apps/GDALRead.cs
to see how to read data into a byte array and then you can write this array
directly to the memory stream.
Best regards,
Tamas
2011/7/31 Maksim Sestic <max at geoinova.com>
Hi all,
Is there any example of OGR driver writing to memory stream (instead of file
stream), in .NET?
Regards,
Maksim Sestic
__________ Information from ESET NOD32 Antivirus, version of virus signature
database 6338 (20110731) __________
The message was checked by ESET NOD32 Antivirus.
http://www.eset.com
gdal-dev mailing list
http://lists.osgeo.org/mailman/listinfo/gdal-dev
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20110803/60c91ea0/attachment.html
