[gdal-dev] C# Bindings warp image using gcp
Edi.Karadumi edikaradumi at gmail.com
Wed Aug 10 09:40:33 EDT 2011
Hello im trying to warp an image using 4 or more gcp points. I have already
done it in c++, but my project is in c# so im trying to convert it. I got
the following example from the GDAL warp API tutorial and adjusted it for my
needs. I have done most of the other parts but i cant convert the following
part
// Establish reprojection transformer.
    psWarpOptions->pTransformerArg =
        GDALCreateGenImgProjTransformer( hSrcDS,
                                         GDALGetProjectionRef(hSrcDS),
                                         hDstDS,
                                         GDALGetProjectionRef(hDstDS),
                                         TRUE, 0.0, 1 );
    psWarpOptions->pfnTransformer = GDALGenImgProjTransform;
I cant find GDALCreateGenImgProjTransformer to create the transformer. How
can i adapt it i C#?
Best Regards
Edi Karadumi
This is the official Example
#include "gdalwarper.h"
int main()
    GDALDatasetH  hSrcDS, hDstDS;
    // Open input and output files.
    GDALAllRegister();
    hSrcDS = GDALOpen( "in.tif", GA_ReadOnly );
    hDstDS = GDALOpen( "out.tif", GA_Update );
    // Setup warp options.
    GDALWarpOptions *psWarpOptions = GDALCreateWarpOptions();
    psWarpOptions->hSrcDS = hSrcDS;
    psWarpOptions->hDstDS = hDstDS;
    psWarpOptions->nBandCount = 1;
    psWarpOptions->panSrcBands =
        (int *) CPLMalloc(sizeof(int) * psWarpOptions->nBandCount );
    psWarpOptions->panSrcBands[0] = 1;
    psWarpOptions->panDstBands =
    psWarpOptions->panDstBands[0] = 1;
    psWarpOptions->pfnProgress = GDALTermProgress;
                                         hDstDS,
                                         FALSE, 0.0, 1 );
    // Initialize and execute the warp operation.
    GDALWarpOperation oOperation;
    oOperation.Initialize( psWarpOptions );
    oOperation.ChunkAndWarpImage( 0, 0,
                                  GDALGetRasterXSize( hDstDS ),
                                  GDALGetRasterYSize( hDstDS ) );
    GDALDestroyGenImgProjTransformer( psWarpOptions->pTransformerArg );
    GDALDestroyWarpOptions( psWarpOptions );
    GDALClose( hDstDS );
    GDALClose( hSrcDS );
    return 0;
View this message in context: http://osgeo-org.1803224.n2.nabble.com/C-Bindings-warp-image-using-gcp-tp6672396p6672396.html
Sent from the GDAL - Dev mailing list archive at Nabble.com.
