[gdal-dev] tiled vector rendering
Jean-François Gigand jf at geonef.fr
Wed Aug 10 19:12:55 EDT 2011
I don't know OSSIM, and I don't understand what you really need to do.
You should understand the concepts first, then express what component
you need, for given inputs and outputs.
"tiled vector rendering engine": does that mean rendering vectors to
an image given style rules, or split large vectors into geographical
square tiles of vectors ?
Jean-François Gigand - Geonef
Paris, France - http://geonef.fr/
2011/8/10 Mohammed Rashad <mohammedrashadkm at gmail.com>:
> now i will tell my requirement for more results from you
> I need a library based on OGR for OSSIM it should be a tiled vector
> rendering engine
> is there any library that I can get to inegrate with OSSIM + GDAL/OGR
> On Wed, Aug 10, 2011 at 9:20 PM, Jean-François Gigand <jf at geonef.fr> wrote:
>> There is QuantumGIS : http://www.qgis.org/
>> Again, not the only one. GRASS can also read GDAL/OGR datasources.
>> Not sure if gvSIG uses the GDAL library, but it supports many formats.
>> Bets regards;
>> > Thanks, I need a desktop library. can you point me to one
>> > On Wed, Aug 10, 2011 at 9:03 PM, Jean-François Gigand <jf at geonef.fr>
>> > wrote:
>> >> Hi Rashad,
>> >> There is MapServer, http://mapserver.org/
>> >> It supports GDAL and OGR sources as input.
>> >> It's not the only one but one of the most famous.
>> >> Best regards,
>> >> > Is there any library which provide tiled vector rendering using
>> >> > GDAL/OGR
>> >> > how to build a tiled vector renderer.?? (big question expect any
>> >> > answer)
>> >> > Anyone please throw some light....
>> >> > Thanks && Regards
>> >> > Rashad
>> >> > _______________________________________________
>> >> > gdal-dev mailing list
>> >> > gdal-dev at lists.osgeo.org
>> >> > http://lists.osgeo.org/mailman/listinfo/gdal-dev
>> > Thanks && Regards
>> > Rashad
> Thanks && Regards
> Rashad
