[gdal-dev] save raster as point-vector file
Chaitanya kumar CH
chaitanya.ch at gmail.com
Thu Aug 11 04:04:32 EDT 2011
What is the output of ogrinfo on the .vrt file?
2011/8/11 Mateusz Kędzior <matandked at gmail.com>
> Hi Chaitanya,
> I say that I don't need to create VRT file, but I was wrong. When I try to
> run ogr2ogr utility:
> ogr2ogr -f GML output_file.gml input_file.csv*
> I discover that created file contain only table - if I choose ESRI
> shapefile as output, I get only dbf file.
> So i try to generate such file:
> <OGRVRTDataSource>
> <OGRVRTLayer name="evap_OBC_OBCXYZn">
> <SrcDataSource>evap_OBC_OBCXYZn.csv</SrcDataSource>
> <GeometryType>wkbPoint</GeometryType>
> <LayerSRS>WGS84</LayerSRS>
> <GeometryField encoding="PointFromColumns" x="Longitude"
> y="Latitude"/>
> </OGRVRTLayer>
> </OGRVRTDataSource>
> but:
> - if I type .vrt file as input I get an empty GML file
> - if I I type .csv file as input I get an output which contain only
> table (without geometry)
> How I can run it properly?
> Which values are allowed in <GeometryField encoding> property?
> Best regards,
> Mateusz
> W dniu 10 sierpnia 2011 05:58 użytkownik Chaitanya kumar CH <
> chaitanya.ch at gmail.com> napisał:
> Mateusz,
>> You have to change the OGRVRTLayer name property to point to the file name
>> without the extension. Also change the SrcDataSource element.
>> FYI, this process creates a vector file with points. gdal_polygonize
>> produces polygons.
>> 2011/8/10 Mateusz Kędzior <matandked at gmail.com>
>>> Hi again,
>>> is it mandatory to create such file?
>>> Regarding to information on GDAL/OGR page should I create simple text
>>> file which contains only other OGRVRTLayer name property :
>>> <OGRVRTDataSource>
>>> <OGRVRTLayer name="test">
>>> <SrcDataSource>test.csv</SrcDataSource>
>>> <GeometryField encoding="PointFromColumns" x="Longitude" y="Latitude"/>
>>> </OGRVRTLayer>
>>> </OGRVRTDataSource>
>>> Best regards,
>>> Mateusz
>>> W dniu 9 sierpnia 2011 20:13 użytkownik Chaitanya kumar CH <
>>>> Create a text file with just the header. Use the cat command to join
>>>> this file and the xyz file.
>>>> $ cat HeaderFile.csv file1.csv > file1.cHi sv
>>>> You can repeat this on all files in a shell script.
>>>> Otherwise add the following line in the gdal2xyz.py script at line 144
>>>> [1].
>>>> dst_fh.write( 'Longitude,Latitude,Name' )
>>>> You will also have to create a separate vrt file for each csv file. The
>>>> SrcDataSource element value changes for each file.
>>>> [1]:
>>>> http://trac.osgeo.org/gdal/browser/trunk/gdal/swig/python/scripts/gdal2xyz.py?rev=21127#L145
>>>> 2011/8/9 Mateusz Kędzior <matandked at gmail.com>
>>>>> Chaitanya,
>>>>> if I understand properly, I need to add one line to each of processed
>>>>> files.
>>>>> How I can do it quickly? Is there any option in gdal2xyz.py script?
>>>>> If no - what would You recommend?
>>>>> I think about sed utility, but it's general difficult in use.
>>>>> When I am thinking about Python I see only one possibility - load each
>>>>> file to variable and then assign to another first line plus variable and at
>>>>> last - save it.
>>>>> Best Regards,
>>>>> Mateusz
>>>>> W dniu 9 sierpnia 2011 13:38 użytkownik Chaitanya kumar CH <
>>>>> Mateusz,
>>>>>> gdal2xyz.py creates space delimited fields. Consider running it with
>>>>>> the -csv option to delimit it with comma.
>>>>>> Now you can almost use it as a csv format vector file. You just need
>>>>>> to add a header row and define a small VRT file as described in OGR's CSV
>>>>>> driver page[1].
>>>>>> Run ogrinfo and ogr2ogr on the .vrt file to check the file.
>>>>>> [1]: http://www.gdal.org/ogr/drv_csv.html
>>>>>>> Hello,
>>>>>>> I would like to show value of each raster cell as label. My idea (I
>>>>>>> don't know any plugin or any functionality in GDAL/OGR which allow to do it
>>>>>>> easier) is to export raster using gdal2xyz.py into coordinates-value format
>>>>>>> and then save it as vector (GML or shapefile). For this second task, I try
>>>>>>> to use
>>>>>>> gdal_polygonize.py:
>>>>>>> gdal_polygonize.py rainfXYZ.txt rainf.shp Creating output rainf.shp
>>>>>>> of format GML. 0...10...20...30...40...50...60...70...80...90...100 - done.
>>>>>>> unfortunately I am unable to load created file (even if I change the
>>>>>>> extension to .gml)
>>>>>>> ogr2ogr tool don't even recognize this format.
>>>>>>> Thank You in advance,
>>>>>>> Mateusz
>>>>>>> _______________________________________________
>>>>>>> gdal-dev mailing list
>>>>>>> gdal-dev at lists.osgeo.org
>>>>>>> http://lists.osgeo.org/mailman/listinfo/gdal-dev
>>>>>> Best regards,
>>>>>> Chaitanya kumar CH.
>>>>>> +91-9494447584
>>>>>> 17.2416N 80.1426E
>>>> Best regards,
>>>> Chaitanya kumar CH.
>>>> +91-9494447584
>>>> 17.2416N 80.1426E
>> Best regards,
>> Chaitanya kumar CH.
>> +91-9494447584
>> 17.2416N 80.1426E
Best regards,
Chaitanya kumar CH.
+91-9494447584
17.2416N 80.1426E
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20110811/e0774aaf/attachment.html
