[gdal-dev] SWIG JNI binding question with GetMetadataItem function
Nikolaos Hatzopoulos
nhatzop at gmail.com
Thu Aug 11 19:56:22 EDT 2011
Did you follow these instructions?
http://trac.osgeo.org/gdal/wiki/GdalOgrInJavaBuildInstructionsUnix
this command must work:
java -classpath `pwd`/gdal.jar:`pwd`:`pwd`/build/apps gdalinfo
as the instruction are saying:
*With luck you will see the gdalinfo usage message. *
and try to see a gdalinfo of a file
--Nikos Hatzopoulos
On Thu, Aug 11, 2011 at 3:21 PM, Jim Pendleton <jimp at ittvis.com> wrote:
> Even,
> Thanks for the suggestion, but if I've implemented your
> suggestion properly, it has not solved the underlying problem.
> >I'm not sure how you've compiled the gdal_warp.cpp, but if you didn't
> >use the provided swig/java/GNUmakefile, there's one point you must be
> >very careful that is mentionned at the bottom of that makefile :
> To create a .so file from source in Android, you generally use the
> ndk-build utility along with one or more Android.mk and Application.mk
> files. I execute the standard make/make install from
> within the swig/java directory, then I compile and link gdal_wrap.cpp
> within the context of a separate ndk-build process.
> Android NDK Release 6 uses GNU Make 3.81 as its build utility.
> The compiler in my case is arm-linux-androideabi-g++ (GCC) 4.4.3.
> The loader is GNU ld (GNU Binutils) 2.19.
> ># Do not remove -fno-strict-aliasing while SWIG generates weird code
> >in upcast methods
> ># See http://trac.osgeo.org/gdal/changeset/16006
> >That would be a plausible cause for the crash, since in your
> >particular case the GetMetadataItem() method is in the MajorObject
> >class, so the Dataset object needs to call the SWIGDatasetUpcast()
> >method...
> Indeed I was lacking the -fno-strict-aliasing switch in the C++ flags in
> my
> Android.mk file.
> However, I've added this switch to both LOCAL_CFLAGS and LOCAL_CPPFLAGS
> for the libgdaljni.so build and I continue to get the error during
> execution.
> To add some more info to my original message, the actual error comes
> from
> within Java_org_gdal_gdal_gdalJNI_MajorObject_1GetMetadataItem_1_1SWIG10
> in
> gdal_wrap.cpp on the call to jenv->GetStringUTFChars(jarg2, 0). First a
> JNI
> warning is issued, then the access violation appears to occur before
> that
> function can return, or at least before a debug statement I've added
> after
> the call can send its output to the Android LogCat output.
> The error that's issued is related to jarg2 which is supposed to be a
> jstring, versus the jarg1 argument you mentioned which requires the
> upcast to GDALMajorObjectShadow.
> I think I'll need to further debug the pointers that are being passed
> down to the *GetMetadataItem*1SWIG10* function. None of them look
> outrageous at first glance.
> Again, there's every reason to believe I'm missing something that's
> otherwise obvious to the experts so please feel free to continue
> sending ideas my way!
> Jim P.
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20110811/6fa74adf/attachment.html
