[gdal-dev] save raster as point-vector file
Chaitanya kumar CH chaitanya.ch at gmail.com
Fri Aug 12 09:15:02 EDT 2011
Mateusz,
Refer to OGR's VRT format driver page.
http://www.gdal.org/ogr/drv_vrt.html
2011/8/11 Mateusz Kędzior <matandked at gmail.com>
> Hi Chaitanya,
> I try to add full path to csv file - is it correct?
> ===================================================NEW VRT
> FILE====================================
> <OGRVRTDataSource>
>     <OGRVRTLayer name="evap_OBCXYZn">
> <SrcDataSource>"/media/windows/studia/2_sem_mgr/mgr/prof_Zawadzki/dods/gldas/00Z07Apr2009_00Z15Apr2009/evap_OBCXYZn.csv"</SrcDataSource>
>         <GeometryType>wkbPoint</GeometryType>
>         <LayerSRS>WGS84</LayerSRS>
>         <GeometryField encoding="PointFromColumns" x="Longitude"
> y="Latitude"/>
>     </OGRVRTLayer>
> </OGRVRTDataSource>
> When I try use ogrinfor I get an error message:
> FAILURE:
> Unable to open datasource `evap_OBCXYZn.vrt' with the following drivers.
> When I use the same tool at csv file I get:
> INFO: Open of `evap_OBCXYZn.csv'
>       using driver `CSV' successful.
> 1: evap_OBCXYZn (None)
> The CSV file contain such information:
> Longitude,Latitude,Name
> 20.132145,52.4227439,1.78132e-05
> 20.382145,52.4227439,1.89083e-05
> and so on..
> How I can change it to get vector-point layer? As I wrote I can only get a
> layer without geometry if I point to csv file.
> Best regards,
> Mateusz
> W dniu 11 sierpnia 2011 10:04 użytkownik Chaitanya kumar CH <
> chaitanya.ch at gmail.com> napisał:
> What is the output of ogrinfo on the .vrt file?
>>> Hi Chaitanya,
>>> I say that I don't need to create VRT file, but I was wrong. When I try
>>> to run ogr2ogr utility:
>>> ogr2ogr -f GML output_file.gml input_file.csv*
>>> I discover that created file contain only table - if I choose ESRI
>>> shapefile as output, I get only dbf file.
>>> So i try to generate such file:
>>> <OGRVRTDataSource>
>>>     <OGRVRTLayer name="evap_OBC_OBCXYZn">
>>>         <SrcDataSource>evap_OBC_OBCXYZn.csv</SrcDataSource>
>>> y="Latitude"/>
>>>     </OGRVRTLayer>
>>> </OGRVRTDataSource>
>>> but:
>>>    - if I type .vrt file as input I get an empty GML file
>>>    - if I I type .csv file as input I get an output which contain only
>>>    table (without geometry)
>>> How I can run it properly?
>>> Which values are allowed in <GeometryField encoding> property?
>>> Best regards,
>>> Mateusz
>>> W dniu 10 sierpnia 2011 05:58 użytkownik Chaitanya kumar CH <
>>> Mateusz,
>>>> You have to change the OGRVRTLayer name property to point to the file
>>>> name without the extension.  Also change the SrcDataSource element.
>>>> FYI, this process creates a vector file with points. gdal_polygonize
>>>> produces polygons.
>>>> 2011/8/10 Mateusz Kędzior <matandked at gmail.com>
>>>>> Hi again,
>>>>> is it mandatory to create such file?
>>>>> Regarding to information on GDAL/OGR page should I create simple text
>>>>> file which contains only other OGRVRTLayer name property :
>>>>> <OGRVRTDataSource>
>>>>>     <OGRVRTLayer name="test">
>>>>>         <SrcDataSource>test.csv</SrcDataSource>
>>>>>         <GeometryField encoding="PointFromColumns" x="Longitude" y="Latitude"/>
>>>>>     </OGRVRTLayer>
>>>>> </OGRVRTDataSource>
>>>>> Best regards,
>>>>> Mateusz
>>>>> W dniu 9 sierpnia 2011 20:13 użytkownik Chaitanya kumar CH <
>>>>>> Create a text file with just the header. Use the cat command to join
>>>>>> this file and the xyz file.
>>>>>> $ cat HeaderFile.csv file1.csv > file1.cHi sv
>>>>>> You can repeat this on all files in a shell script.
>>>>>> Otherwise add the following line in the gdal2xyz.py script at line 144
>>>>>> [1].
>>>>>> dst_fh.write( 'Longitude,Latitude,Name' )
>>>>>> You will also have to create a separate vrt file for each csv file.
>>>>>> The SrcDataSource element value changes for each file.
>>>>>> [1]:
>>>>>> http://trac.osgeo.org/gdal/browser/trunk/gdal/swig/python/scripts/gdal2xyz.py?rev=21127#L145
>>>>>> 2011/8/9 Mateusz Kędzior <matandked at gmail.com>
>>>>>>> Chaitanya,
>>>>>>> if I understand properly, I need to add one line to each of processed
>>>>>>> files.
>>>>>>> How I can do it quickly? Is there any option in gdal2xyz.py script?
>>>>>>> If no - what would You recommend?
>>>>>>> I think about sed utility, but it's general difficult in use.
>>>>>>> When I am thinking about Python I see only one possibility - load
>>>>>>> each file to variable and then assign to another first line plus variable
>>>>>>> and at last - save it.
>>>>>>> Best Regards,
>>>>>>> Mateusz
>>>>>>> W dniu 9 sierpnia 2011 13:38 użytkownik Chaitanya kumar CH <
>>>>>>> Mateusz,
>>>>>>>> gdal2xyz.py creates space delimited fields. Consider running it with
>>>>>>>> the -csv option to delimit it with comma.
>>>>>>>> Now you can almost use it as a csv format vector file. You just need
>>>>>>>> to add a header row and define a small VRT file as described in OGR's CSV
>>>>>>>> driver page[1].
>>>>>>>> Run ogrinfo and ogr2ogr on the .vrt file to check the file.
>>>>>>>> [1]: http://www.gdal.org/ogr/drv_csv.html
>>>>>>>>> Hello,
>>>>>>>>> I would like to show value of each raster cell as label. My idea (I
>>>>>>>>> don't know any plugin or any functionality in GDAL/OGR which allow to do it
>>>>>>>>> easier) is to export raster using gdal2xyz.py into coordinates-value format
>>>>>>>>> and then save it as vector (GML or shapefile). For this second task, I try
>>>>>>>>> to use
>>>>>>>>> gdal_polygonize.py:
>>>>>>>>> gdal_polygonize.py rainfXYZ.txt rainf.shp Creating output rainf.shp
>>>>>>>>> of format GML. 0...10...20...30...40...50...60...70...80...90...100 - done.
>>>>>>>>> unfortunately I am unable to load created file (even if I change
>>>>>>>>> the extension to .gml)
>>>>>>>>> ogr2ogr tool don't even recognize this format.
>>>>>>>>> Thank You in advance,
>>>>>>>>> Mateusz
>>>>>>>>> _______________________________________________
>>>>>>>>> gdal-dev mailing list
>>>>>>>>> gdal-dev at lists.osgeo.org
>>>>>>>>> http://lists.osgeo.org/mailman/listinfo/gdal-dev
>>>>>>>> Best regards,
>>>>>>>> Chaitanya kumar CH.
>>>>>>>> +91-9494447584
>>>>>>>> 17.2416N 80.1426E
>>>>>> Best regards,
>>>>>> Chaitanya kumar CH.
>>>>>> +91-9494447584
>>>>>> 17.2416N 80.1426E
>>>> Best regards,
>>>> Chaitanya kumar CH.
>>>> +91-9494447584
>>>> 17.2416N 80.1426E
>> Best regards,
>> Chaitanya kumar CH.
>> +91-9494447584
>> 17.2416N 80.1426E
Best regards,
Chaitanya kumar CH.
+91-9494447584
17.2416N 80.1426E
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20110812/bc2d2349/attachment-0001.html
