[gdal-dev] SWIG JNI binding question with GetMetadataItem function
Nikolaos Hatzopoulos nhatzop at gmail.com
Tue Aug 23 12:19:35 EDT 2011
yes watch that because they also added test so you can do:
make test
and see if the swing is working
--Nikos Hatzopoulos
On Tue, Aug 23, 2011 at 8:53 AM, Jim Pendleton <jimp at ittvis.com> wrote:
> Just to finalize this thread, the underlying problem was that the
> version of SWIG I was using was outdated.  Installing version 2.0.5
> corrected the issue.
> Jim P.
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20110823/43c21a55/attachment.html
