GDALers: I really like gdal.retile.py, but I'm now facing an issue where I want to tile a file but have *overlap* between each tile. Is there a way to do this using existing GDAL utilities? I want the outputs to be geotiffs, and (ideally, but not required) I'd like a shapefile generated of the results. Thanks! --j
