[gdal-dev] Using GDAL to tile an image *with* overlapping?
Jonathan Greenberg
jgrn at illinois.edu
Wed Aug 24 21:09:28 EDT 2011
Re: the shapefile: I'm just referring to this flag:
-tileIndex tileIndexName:
The name of shape file containing the result tile(s) index
I don't know python, so I'll probably go ahead and code this
functionality up in R via rgdal/raster, but perhaps this can be listed
as a feature request? The reason I want to tile the data is to
perform some spatial processing -- I need an overlap between tiles to
deal with the fact that I'm using local windows to process the image
subsets.
--j
On Wed, Aug 24, 2011 at 2:20 AM, Chaitanya kumar CH
<chaitanya.ch at gmail.com> wrote:
> Jonathan,
> I think you will have to modify the gdal_retile.py script[1] yourselves.
> Can you explain what you mean by the shapefile of the results?
> [1]:
> http://trac.osgeo.org/gdal/browser/trunk/gdal/swig/python/scripts/gdal_retile.py
> On Wed, Aug 24, 2011 at 2:17 AM, Jonathan Greenberg <jgrn at illinois.edu>
> wrote:
>> GDALers:
>> I really like gdal.retile.py, but I'm now facing an issue where I want
>> to tile a file but have *overlap* between each tile. Is there a way
>> to do this using existing GDAL utilities? I want the outputs to be
>> geotiffs, and (ideally, but not required) I'd like a shapefile
>> generated of the results. Thanks!
>> --j
>> gdal-dev mailing list
>> gdal-dev at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/gdal-dev
> Best regards,
> Chaitanya kumar CH.
> +91-9494447584
> 17.2416N 80.1426E
