[gdal-dev] pruge images
Brian Case rush at winkey.org
Fri Aug 26 09:48:49 EDT 2011
Jan
if you already have a wms setup with your data you could use the wms
driver to read it. gdal_translate to a bigtiff. then cut it up into
tiles with gdal_translate -srcwin
Brian
On Fri, 2011-08-26 at 15:17 +0200, Jan Tappenbeck wrote:
>   hi!
> i have following problem. openstreetmap could be download images by
> aerowest for drawing elementes. the download had to taken manuell and so
> it is not possible to create leaf cut off images.
> know i want to clean my gallery in hope to get more performance in my
> local wms-service.
> did anybody had a idea to merge all the images (georef!) distributed
> over the hole town and cut then regualar without overlap?!?!?
> regards Jan :-)
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
