[gdal-dev] Problem to merge 2 images
Chaitanya kumar CH chaitanya.ch at gmail.com
Fri Aug 26 10:12:32 EDT 2011
Jan,
The first error message is because of the block size. The entire image is
taken as a block; not good for large rasters. When copying, GDAL tries to
load the entire block into the memory.
It's very likely that the problem will be resolved if we create copies of
the gtiffs with smaller blocks. Use gdal_translate with the -co option[1] to
set the BLOCKXSIZE and BLOCKYSIZE [2] of the output image. Since the
datatype of the gtiffs is byte set them both to 1024. Decrease it to 512 or
256 if the problem persists.
[1]: http://www.gdal.org/gdal_translate.html
[2]: http://www.gdal.org/frmt_gtiff.html
On Fri, Aug 26, 2011 at 6:31 PM, Jan Tappenbeck <tappenbeck at widemann.de>wrote:
>  hi !
> i have got two images to merge and convert into ecw - but i only get a
> error-message and a black image.
> i send following command:
> gdal_merge.bat -of GTiff -o D:/GDAL_Projekte/xxxxxxxxxx/**xxxxxxxxxx_gesamt.tif
> D:/GDAL_Projekte/xxxxxxxxxx/**xxxxxxxxxx_300_nord_geo.tif
> D:/GDAL_Projekte/xxxxxxxxxx/**xxxxxxxxxx_300_sued_geo.tif
> gdal_translate -of ECW -co LARGE_OK=YES D:/GDAL_Projekte/xxxxxxxxxx/**xxxxxxxxxx_gesamt.tif
> D:/GDAL_Projekte/xxxxxxxxxx/**xxxxxxxxxx_gesamt.ecw
> and here are the image-infos and the message - can anybody help me?
> reagards Jan :-)
> C:\Program Files (x86)\FWTools2.4.7>gdalinfo D:/GDAL_Projekte/XXXXXXX/**
> XXXXXXX_
> 300_nord_geo.tif
> Driver: GTiff/GeoTIFF
> Files: D:/GDAL_Projekte/XXXXXXX/**XXXXXXX_300_nord_geo.tif
>       D:/GDAL_Projekte/XXXXXXX/**XXXXXXX_300_nord_geo.tfw
> Size is 25848, 19395
> Coordinate System is:
> PROJCS["unnamed",
>    GEOGCS[,
>        DATUM["unknown",
>            SPHEROID["unretrievable - using WGS84",6378137,298.257223563]]*
>        PRIMEM["Greenwich",0],
>        UNIT[,0.0174532925199433]],
>    UNIT["unknown",1]]
> Origin = (3551283.342142190800000,**5917001.142321675100000)
> Pixel Size = (0.423322208955370,-0.**423342973054873)
> Metadata:
>  TIFFTAG_SOFTWARE=WGEO 3.0.0.69 VKB KAWinsen2
>  TIFFTAG_XRESOLUTION=300
>  TIFFTAG_YRESOLUTION=300
>  AREA_OR_POINT=Area
> Image Structure Metadata:
>  COMPRESSION=PACKBITS
>  INTERLEAVE=BAND
>  MINISWHITE=YES
> Corner Coordinates:
> Upper Left  ( 3551283.342, 5917001.142)
> Lower Left  ( 3551283.342, 5908790.405)
> Upper Right ( 3562225.375, 5917001.142)
> Lower Right ( 3562225.375, 5908790.405)
> Center      ( 3556754.358, 5912895.774)
> Band 1 Block=25848x19393 Type=Byte, ColorInterp=Palette
>    NBITS=1
>  Color Table (RGB with 2 entries)
>    0: 255,255,255,255
>    1: 0,0,0,255
> XXXXXXX_
> 300_sued_geo.tif
> Files: D:/GDAL_Projekte/XXXXXXX/**XXXXXXX_300_sued_geo.tif
>       D:/GDAL_Projekte/XXXXXXX/**XXXXXXX_300_sued_geo.tfw
> Size is 25849, 19394
> PROJCS["unnamed",
>    GEOGCS[,
>        DATUM["unknown",
>    UNIT["unknown",1]]
> Origin = (3551215.913367207200000,**5909585.856755478300000)
> Pixel Size = (0.423327969973589,-0.**423338937597159)
> Metadata:
>  AREA_OR_POINT=Area
>  INTERLEAVE=BAND
>  MINISWHITE=YES
> Corner Coordinates:
> Upper Left  ( 3551215.913, 5909585.857)
> Lower Left  ( 3551215.913, 5901375.621)
> Upper Right ( 3562158.518, 5909585.857)
> Lower Right ( 3562158.518, 5901375.621)
> Center      ( 3556687.216, 5905480.739)
> Band 1 Block=25849x19393 Type=Byte, ColorInterp=Palette
>    NBITS=1
>    0: 255,255,255,255
>    1: 0,0,0,255
> C:\Program Files (x86)\FWTools2.4.7>D:\GDAL_**Projekte\XXXXXXX\XXXXXXX.bat
> C:\Program Files (x86)\FWTools2.4.7>gdal_merge.**bat -of GTiff -o
> D:/GDAL_Projekte
> /XXXXXXX/XXXXXXX_gesamt.tif D:/GDAL_Projekte/XXXXXXX/**
> f D:/GDAL_Projekte/XXXXXXX/**XXXXXXX_300_sued_geo.tif
> ERROR 4: `D:/GDAL_Projekte/XXXXXXX/**XXXXXXX_gesamt.tif' not recognised as
> a sup
> ported file format.
> 0ERROR 2: GDALRasterBlock::Internalize : Out of memory allocating 501270264
> byte
> s.
> ERROR 1: GetBlockRef failed at X block offset 0, Y block offset 1
> Traceback (most recent call last):
>  File "C:\PROGRA~2\FWTOOL~1.7\bin\**gdal_merge.py", line 472, in ?
>    sys.exit(main())
>  File "C:\PROGRA~2\FWTOOL~1.7\bin\**gdal_merge.py", line 459, in main
>    fi.copy_into( t_fh, band, band, nodata )
>  File "C:\PROGRA~2\FWTOOL~1.7\bin\**gdal_merge.py", line 231, in copy_into
>    nodata_arg )
>  File "C:\PROGRA~2\FWTOOL~1.7\bin\**gdal_merge.py", line 62, in
> raster_copy
>    t_xsize, t_ysize, t_band.DataType )
>  File "C:\PROGRA~2\FWTOOL~1.7\pymod\**gdal.py", line 851, in ReadRaster
>    buf_xsize, buf_ysize,buf_type)
> TypeError: GetBlockRef failed at X block offset 0, Y block offset 1
> ______________________________**_________________
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> http://lists.osgeo.org/**mailman/listinfo/gdal-dev<http://lists.osgeo.org/mailman/listinfo/gdal-dev>
Best regards,
Chaitanya kumar CH.
+91-9494447584
17.2416N 80.1426E
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20110826/19af569d/attachment-0001.html
