[gdal-dev] Projection definition issue with Mapinfo files
Yves Jacolin yjacolin at free.fr
Mon Aug 29 07:34:22 EDT 2011
Hello,
One of QGIS user report an issue with mapInfo file (TAB file). If you understand
french you can see the thread here:
http://georezo.net/forum/viewtopic.php?pid=197022
I try to sum up the issue in english in this email. The process is basicly as
follow:
1. check projection information with ogrinfo
> DATUM["GRS_80",
>             SPHEROID["GRS 80",6378137,298.257222101],
2. update projection information file with ogr2ogr:
> ogr2ogr -f "MapInfo file" -s_srs "EPSG:2154" -t_srs "EPSG:2154" new.tab
origin.tab
3. check projection information with ogrinfo
> DATUM["WGS_1984",
>             SPHEROID["WGS 84",6378137,298.257223563],
1 and 3 show differents projection information! If I try to change file format
to shp, it seems that projection information are correct.
I can share tab files if needed.
Any idea? Thanks.
Y.
Yves Jacolin
http://yjacolin.gloobe.org
