[gdal-dev] GTiff optimisation
Etienne Tourigny
etiennesky at yahoo.com
Tue Aug 30 09:09:13 EDT 2011
Bonjour Yves,
I think that gdalwarp is not optimized for saving compressed geotiffs, you would have to do that in a second step. This topic has been addressed in this list not long ago.
Anyway, you should be using gdal_translate (with a_srs flag) instead for this
task, as you are just adding georeferencing information, not
re-projecting the data.
something like gdal_translate -co "COMPRESS=PACKBITS" -co "PHOTOMETRIC=MINISWHITE" -co "NBITS=1" -a_srs "EPSG:2154" input.tif output.tif
Etienne
----- Original Message -----
To: gdal-dev <gdal-dev at lists.osgeo.org>
Cc:
Sent: Tuesday, August 30, 2011 8:22:46 AM
Subject: [gdal-dev] GTiff optimisation
Hello,
I am converting GTiff to GTiff in order to add projection and georeferencing
information in the header. I am using gdalwarp with some flags, mailny -co
flags. I have some question about this.
Here is my command line:
gdalwarp -co "COMPRESS=PACKBITS" -co "PHOTOMETRIC=MINISWHITE" -co "NBITS=1" -
s_srs "EPSG:2154" -t_srs "EPSG:2154" input.tif output.tif
1. File size: input.tif and output.tif have different file size, output file is
50 % bigger than the input file. Is it normal?
2. If I use gdalinfo on my output file, I have no information about MINISWHITE
parameter while I have it in the input file. Am I using this creation option
correctly? This issue could be related to the first item?
3. I also have a "AREA_OR_POINT=Area" item in my output from gdalinfo, what
does it means?
gdal version: GDAL 1.7.3, released 2010/11/10
thanks,
Y.
Yves Jacolin
http://yjacolin.gloobe.org
gdal-dev mailing list
http://lists.osgeo.org/mailman/listinfo/gdal-dev
