Thank for both of you, I will try according to your suggestion. -- View this message in context: http://osgeo-org.1803224.n2.nabble.com/The-problem-when-using-ReadRaster-C-method-tp6745826p6746581.html Sent from the GDAL - Dev mailing list archive at Nabble.com.
