[gdal-dev] GTiff optimisation
Jean-Claude Repetto jrepetto at free.fr
Wed Aug 31 10:45:09 EDT 2011
Le 31/08/2011 14:13, Yves Jacolin a écrit :
> Another question: I have 2 000 ECW files (40 Mo each), 49 ECW files (1 Go each)
> and 2 ECW files (2 Go each). I worked first on 2 Go ECW file, it takes around 1
> day to assign the projection information in the files.
> Do you think this is normal? How can I improve this?
Since you are using Linux, you may be interested in a tool I wrote a few
years ago :
http://jrepetto.free.fr/ecwhed/
You can compile it manually by a command such as :
g++ -o ecwhed -l pthread  ecwhed.cpp /usr/lib64/libecwj2.a
( The standard procedure ./configure; make; make install is not working
anymore. If you know the autotools, may be you can fix it).
Jean-Claude
