[gdal-dev] ogr2ogr - output WKT to console?
Elijah Robison
elijah at villagis.com
Wed Aug 31 16:44:55 EDT 2011
Hi Devs,
When troubleshooting geodata integrity issues, we sometimes use ogr2ogr
to push WKT expressions to a .csv file using a script like I show below.
It uses an ogr sql statement to grab a single feature from a raw
shapefile data source, then it saves the output to a CSV:
ogr2ogr -f "CSV" "C:\xData\CountyData\Shps\OriginalParcelCSV"
"C:\xData\CountyData\Shps\parcel_polygons.shp" -sql "select * from
parcel_polygons where id= 9080" -lco "GEOMETRY=AS_WKT" -lco
"LINEFORMAT=CRLF" -lco "SEPARATOR=SEMICOLON"
As our needs in this situation are very transient, I'm curious if it is
possible to output the WKT directly to the console?
Very Best,
Elijah Robison
