[gdal-dev] Re: Add an option to allow opening datasets/datasources from SWIG bindings even in case of error ?
Ari Jolma ari.jolma at gmail.com
Thu Dec 1 02:09:41 EST 2011
On 11/30/2011 10:20 PM, Even Rouault wrote:
> Hi SWIG binding users/devs,
> Any opinion on http://trac.osgeo.org/gdal/ticket/4360 ?
> """After the changes done in
> http://trac.osgeo.org/gdal/changeset/11529 /
> http://trac.osgeo.org/gdal/ticket/1635 , any CE_Failure error emitted
> by CPLError() in the Open() method of GDAL and OGR drivers, and not
> cleared, will cause the swig bindings to return a null dataset, even
> if the driver returned a valid one.
> Sometimes those errors are not critical, and users regularly complain
> (last occurrence is
>  http://lists.osgeo.org/pipermail/gdal-dev/2011-November/030960.html
> <http://lists.osgeo.org/pipermail/gdal-dev/2011-November/030960.html>
> ) that they can open them successfully with C/C++ API, but not from
> Java/Python/etc, so I'd suggest the following patch that adds a
> bIgnoreErrors option, that if turned on will reset the error flag in
> the case discussed here. By default, the new option is not turned on. """
GDAL has warnings, failures and fatal errors. I don't know the
semantical error between a failure and a fatal error and they are
treated the same in the bindings. Also at least in Perl there are only
tools for warnings and (fatal) errors. Is this a case of a failure but
not a fatal error and the sign is that the returned value is ok but
there is a failure state. Maybe we should convert the failure into a
warning in such a case? I guess that would be my suggestion.
I usually think about these from the point of view of somebody using a
GUI and I don't see a checkbox in open vector dataset dialog box for
"ignore errors".
I'm concerned about the viability of the returned dataset object - it is
ok if the user is warned and given a not perfect object, but it is not
ok to return an object, which may lead to core dumps or other bad things.
Ari
> Best regards,
> Even
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20111201/08bda66a/attachment.html
