[gdal-dev] Support for MISR data processing.
Wesley Roberts
wroberts at csir.co.za
Thu Dec 1 05:25:17 EST 2011
Unfortunately not, it is a level 2 land surface product downloaded from the site below.
I have several data sets whose size is well below 5 MB. I could email you one of them off-list if you like?
W.
>>> Chaitanya kumar CH <chaitanya.ch at gmail.com> 01/12/2011 11:38 >>>
Wesley,
Can you provide the exact link for the dataset or a page containing the
link?
On Thu, Dec 1, 2011 at 2:33 PM, Wesley Roberts <wroberts at csir.co.za> wrote:
> Dear gdal-dev,
> I have some MISR hdf data downloaded from the following website (
> http://eosweb.larc.nasa.gov/PRODOCS/misr/table_misr.html). I have tried
> to use gdal to access the hdf data using techniques similar to other hdf
> data sources (MODIS - NDVI and ET). gdalinfo is able to read the contents
> of the data file in much the same way as it does with MODIS data products.
> See below, however when I use gdal_translate to extract my data set of
> interest the result is incorrect. The command executes as per normal and
> writes a data set to my disk, however when I look at the result in QGIS I
> see that the image is flippped to the left (north now faces west) and that
> the data is jumbled (white noise). The command I am using is below. Any
> help on extracting MISR data blocks is greatly appreciated.
> Many thanks,
> Wesley
> ###################################################gdal_translate###################################################
> gdal_translate -of GTiff
> "HDF4_EOS:EOS_GRID:"MISR_AM1_AS_LAND_P174_O001092_F07_0022.b117-118.hdf":RegParamsLnd:NormBlkSfcIrrad"
> output.tif
> ###################################################gdalinfo###################################################
> gdalinfo MISR_AM1_AS_LAND_P174_O001092_F07_0022.b117-118.hdf
> Driver: HDF4/Hierarchical Data Format Release 4
> Files: MISR_AM1_AS_LAND_P174_O001092_F07_0022.b117-118.hdf
> Size is 512, 512
> Coordinate System is `'
> Metadata:
> HDFEOSVersion=HDFEOS_V2.13
> Path_number=174
> AGP_version_id=2
> DID_version_id=4
> Number_blocks=180
> Ocean_blocks_size=180
> Ocean_blocks.count=50
> Ocean_blocks.numbers=5, 8, 9, 10, 11, 12, 13, 14, 15, 16, 17, 18, 19, 20,
> 21, 119, 120, 121, 122, 123, 124, 125, 126, 127, 128, 129, 130, 131, 132,
> 133, 134, 135, 136, 137, 138, 139, 140, 141, 142, 143, 144, 145, 146, 174,
> 175, 176, 177, 178, 179, 180, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
> 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
> SOM_parameters.som_ellipsoid.a=6378137
> SOM_parameters.som_ellipsoid.e2=0.006694348
> SOM_parameters.som_orbit.aprime=1
> SOM_parameters.som_orbit.eprime=1
> SOM_parameters.som_orbit.gama=1
> SOM_parameters.som_orbit.nrev=233
> SOM_parameters.som_orbit.ro=7078040.8
> SOM_parameters.som_orbit.i=1.71572532628785
> SOM_parameters.som_orbit.P2P1=0.0686666666666667
> SOM_parameters.som_orbit.lambda0=-2.43535567370853
> Origin_block.ulc.x=7460750
> Origin_block.ulc.y=527450
> Origin_block.lrc.x=7601550
> Origin_block.lrc.y=1090650
> Start_block=117
> End block=118
> Cam_mode=1
> Num_local_modes=0
> Local_mode_site_name=
> Orbit_QA=0
> coremetadata=
> ############################################LOTS of Metadata
> Removed##################################################################
> Subdatasets:
> SUBDATASET_1_NAME=HDF4_EOS:EOS_GRID:"MISR_AM1_AS_LAND_P174_O001092_F07_0022.b117-118.hdf":RegParamsLnd:NormBlkSfcIrrad
> SUBDATASET_1_DESC=[180x8x32x4] NormBlkSfcIrrad RegParamsLnd (32-bit
> floating-point)
> SUBDATASET_2_NAME=HDF4_EOS:EOS_GRID:"MISR_AM1_AS_LAND_P174_O001092_F07_0022.b117-118.hdf":RegParamsLnd:NormBlkSfcIrradUnc
> SUBDATASET_2_DESC=[180x8x32x4] NormBlkSfcIrradUnc RegParamsLnd (32-bit
> floating-point)
> SUBDATASET_3_NAME=HDF4_EOS:EOS_GRID:"MISR_AM1_AS_LAND_P174_O001092_F07_0022.b117-118.hdf":RegParamsLnd:BOABihemAlb
> SUBDATASET_3_DESC=[180x8x32x4] BOABihemAlb RegParamsLnd (32-bit
> floating-point)
> SUBDATASET_4_NAME=HDF4_EOS:EOS_GRID:"MISR_AM1_AS_LAND_P174_O001092_F07_0022.b117-118.hdf":RegParamsLnd:BOABihemAlbUnc
> SUBDATASET_4_DESC=[180x8x32x4] BOABihemAlbUnc RegParamsLnd (32-bit
> floating-point)
> SUBDATASET_5_NAME=HDF4_EOS:EOS_GRID:"MISR_AM1_AS_LAND_P174_O001092_F07_0022.b117-118.hdf":RegParamsLnd:RegSfcRetrOptDepth
> SUBDATASET_5_DESC=[180x8x32] RegSfcRetrOptDepth RegParamsLnd (32-bit
> floating-point)
> SUBDATASET_6_NAME=HDF4_EOS:EOS_GRID:"MISR_AM1_AS_LAND_P174_O001092_F07_0022.b117-118.hdf":RegParamsLnd:RegSfcRetrOptDepthUnc
> SUBDATASET_6_DESC=[180x8x32] RegSfcRetrOptDepthUnc RegParamsLnd (32-bit
> floating-point)
> SUBDATASET_7_NAME=HDF4_EOS:EOS_GRID:"MISR_AM1_AS_LAND_P174_O001092_F07_0022.b117-118.hdf":RegParamsLnd:RegSfcRetrMixture
> SUBDATASET_7_DESC=[180x8x32] RegSfcRetrMixture RegParamsLnd (8-bit
> unsigned integer)
> SUBDATASET_8_NAME=HDF4_EOS:EOS_GRID:"MISR_AM1_AS_LAND_P174_O001092_F07_0022.b117-118.hdf":RegParamsLnd:RegSfcRetrAlgTypeFlag
> SUBDATASET_8_DESC=[180x8x32] RegSfcRetrAlgTypeFlag RegParamsLnd (8-bit
> unsigned integer)
> SUBDATASET_9_NAME=HDF4_EOS:EOS_GRID:"MISR_AM1_AS_LAND_P174_O001092_F07_0022.b117-118.hdf":RegParamsLnd:LandQA
> SUBDATASET_9_DESC=[180x8x32] LandQA RegParamsLnd (8-bit unsigned integer)
> SUBDATASET_10_NAME=HDF4_EOS:EOS_GRID:"MISR_AM1_AS_LAND_P174_O001092_F07_0022.b117-118.hdf":RegParamsLnd:SolZenAng
> SUBDATASET_10_DESC=[180x8x32] SolZenAng RegParamsLnd (32-bit
> floating-point)
> SUBDATASET_11_NAME=HDF4_EOS:EOS_GRID:"MISR_AM1_AS_LAND_P174_O001092_F07_0022.b117-118.hdf":RegParamsLnd:ViewZenAng
> SUBDATASET_11_DESC=[180x8x32x9] ViewZenAng RegParamsLnd (32-bit
> floating-point)
> SUBDATASET_12_NAME=HDF4_EOS:EOS_GRID:"MISR_AM1_AS_LAND_P174_O001092_F07_0022.b117-118.hdf":RegParamsLnd:RelViewCamAziAng
> SUBDATASET_12_DESC=[180x8x32x9] RelViewCamAziAng RegParamsLnd (32-bit
> floating-point)
> SUBDATASET_13_NAME=HDF4_EOS:EOS_GRID:"MISR_AM1_AS_LAND_P174_O001092_F07_0022.b117-118.hdf":RegParamsLnd:ScatterAng
> SUBDATASET_13_DESC=[180x8x32x9] ScatterAng RegParamsLnd (32-bit
> floating-point)
> SUBDATASET_14_NAME=HDF4_EOS:EOS_GRID:"MISR_AM1_AS_LAND_P174_O001092_F07_0022.b117-118.hdf":RegParamsLnd:GlitterAng
> SUBDATASET_14_DESC=[180x8x32x9] GlitterAng RegParamsLnd (32-bit
> floating-point)
> SUBDATASET_15_NAME=HDF4_EOS:EOS_GRID:"MISR_AM1_AS_LAND_P174_O001092_F07_0022.b117-118.hdf":SubregParamsLnd:LandHDRF
> SUBDATASET_15_DESC=[180x128x512x4x9] LandHDRF SubregParamsLnd (16-bit
> unsigned integer)
> SUBDATASET_16_NAME=HDF4_EOS:EOS_GRID:"MISR_AM1_AS_LAND_P174_O001092_F07_0022.b117-118.hdf":SubregParamsLnd:LandHDRFUnc
> SUBDATASET_16_DESC=[180x128x512x4x9] LandHDRFUnc SubregParamsLnd (16-bit
> unsigned integer)
> SUBDATASET_17_NAME=HDF4_EOS:EOS_GRID:"MISR_AM1_AS_LAND_P174_O001092_F07_0022.b117-118.hdf":SubregParamsLnd:RDQI
> SUBDATASET_17_DESC=[180x128x512x4x9] RDQI SubregParamsLnd (8-bit unsigned
> integer)
> SUBDATASET_18_NAME=HDF4_EOS:EOS_GRID:"MISR_AM1_AS_LAND_P174_O001092_F07_0022.b117-118.hdf":SubregParamsLnd:LandBHR
> SUBDATASET_18_DESC=[180x128x512x4] LandBHR SubregParamsLnd (8-bit
> unsigned integer)
> SUBDATASET_19_NAME=HDF4_EOS:EOS_GRID:"MISR_AM1_AS_LAND_P174_O001092_F07_0022.b117-118.hdf":SubregParamsLnd:LandBHRRelUnc
> SUBDATASET_19_DESC=[180x128x512x4] LandBHRRelUnc SubregParamsLnd (8-bit
> unsigned integer)
> SUBDATASET_20_NAME=HDF4_EOS:EOS_GRID:"MISR_AM1_AS_LAND_P174_O001092_F07_0022.b117-118.hdf":SubregParamsLnd:LandBRF
> SUBDATASET_20_DESC=[180x128x512x4x9] LandBRF SubregParamsLnd (16-bit
> unsigned integer)
> SUBDATASET_21_NAME=HDF4_EOS:EOS_GRID:"MISR_AM1_AS_LAND_P174_O001092_F07_0022.b117-118.hdf":SubregParamsLnd:LandDHR
> SUBDATASET_21_DESC=[180x128x512x4] LandDHR SubregParamsLnd (8-bit
> unsigned integer)
> SUBDATASET_22_NAME=HDF4_EOS:EOS_GRID:"MISR_AM1_AS_LAND_P174_O001092_F07_0022.b117-118.hdf":SubregParamsLnd:BRFModParam1
> SUBDATASET_22_DESC=[180x128x512x4] BRFModParam1 SubregParamsLnd (16-bit
> unsigned integer)
> SUBDATASET_23_NAME=HDF4_EOS:EOS_GRID:"MISR_AM1_AS_LAND_P174_O001092_F07_0022.b117-118.hdf":SubregParamsLnd:BRFModParam2
> SUBDATASET_23_DESC=[180x128x512x4] BRFModParam2 SubregParamsLnd (8-bit
> unsigned integer)
> SUBDATASET_24_NAME=HDF4_EOS:EOS_GRID:"MISR_AM1_AS_LAND_P174_O001092_F07_0022.b117-118.hdf":SubregParamsLnd:BRFModParam3
> SUBDATASET_24_DESC=[180x128x512x4] BRFModParam3 SubregParamsLnd (8-bit
> unsigned integer)
> SUBDATASET_25_NAME=HDF4_EOS:EOS_GRID:"MISR_AM1_AS_LAND_P174_O001092_F07_0022.b117-118.hdf":SubregParamsLnd:BRFModFitResid
> SUBDATASET_25_DESC=[180x128x512x4] BRFModFitResid SubregParamsLnd (16-bit
> unsigned integer)
> SUBDATASET_26_NAME=HDF4_EOS:EOS_GRID:"MISR_AM1_AS_LAND_P174_O001092_F07_0022.b117-118.hdf":SubregParamsLnd:NDVI
> SUBDATASET_26_DESC=[180x128x512] NDVI SubregParamsLnd (8-bit unsigned
> integer)
> SUBDATASET_27_NAME=HDF4_EOS:EOS_GRID:"MISR_AM1_AS_LAND_P174_O001092_F07_0022.b117-118.hdf":SubregParamsLnd:BiomeBestEstimate
> SUBDATASET_27_DESC=[180x128x512] BiomeBestEstimate SubregParamsLnd (8-bit
> unsigned integer)
> SUBDATASET_28_NAME=HDF4_EOS:EOS_GRID:"MISR_AM1_AS_LAND_P174_O001092_F07_0022.b117-118.hdf":SubregParamsLnd:BiomeBestEstimateQA
> SUBDATASET_28_DESC=[180x128x512] BiomeBestEstimateQA SubregParamsLnd
> SUBDATASET_29_NAME=HDF4_EOS:EOS_GRID:"MISR_AM1_AS_LAND_P174_O001092_F07_0022.b117-118.hdf":SubregParamsLnd:LAIBestEstimate
> SUBDATASET_29_DESC=[180x128x512] LAIBestEstimate SubregParamsLnd (32-bit
> floating-point)
> SUBDATASET_30_NAME=HDF4_EOS:EOS_GRID:"MISR_AM1_AS_LAND_P174_O001092_F07_0022.b117-118.hdf":SubregParamsLnd:LAIBestEstimateQA
> SUBDATASET_30_DESC=[180x128x512] LAIBestEstimateQA SubregParamsLnd (8-bit
> unsigned integer)
> SUBDATASET_31_NAME=HDF4_EOS:EOS_GRID:"MISR_AM1_AS_LAND_P174_O001092_F07_0022.b117-118.hdf":SubregParamsLnd:FPARBestEstimate
> SUBDATASET_31_DESC=[180x128x512] FPARBestEstimate SubregParamsLnd (32-bit
> floating-point)
> SUBDATASET_32_NAME=HDF4_EOS:EOS_GRID:"MISR_AM1_AS_LAND_P174_O001092_F07_0022.b117-118.hdf":SubregParamsLnd:BHRPAR
> SUBDATASET_32_DESC=[180x128x512] BHRPAR SubregParamsLnd (32-bit
> floating-point)
> SUBDATASET_33_NAME=HDF4_EOS:EOS_GRID:"MISR_AM1_AS_LAND_P174_O001092_F07_0022.b117-118.hdf":SubregParamsLnd:DHRPAR
> SUBDATASET_33_DESC=[180x128x512] DHRPAR SubregParamsLnd (32-bit
> floating-point)
> SUBDATASET_34_NAME=HDF4_EOS:EOS_GRID:"MISR_AM1_AS_LAND_P174_O001092_F07_0022.b117-118.hdf":SubregParamsLnd:LAIMean1
> SUBDATASET_34_DESC=[180x128x512x6] LAIMean1 SubregParamsLnd (8-bit
> unsigned integer)
> SUBDATASET_35_NAME=HDF4_EOS:EOS_GRID:"MISR_AM1_AS_LAND_P174_O001092_F07_0022.b117-118.hdf":SubregParamsLnd:LAIDelta1
> SUBDATASET_35_DESC=[180x128x512x6] LAIDelta1 SubregParamsLnd (32-bit
> floating-point)
> SUBDATASET_36_NAME=HDF4_EOS:EOS_GRID:"MISR_AM1_AS_LAND_P174_O001092_F07_0022.b117-118.hdf":SubregParamsLnd:LAINumGoodFit1
> SUBDATASET_36_DESC=[180x128x512x6] LAINumGoodFit1 SubregParamsLnd (8-bit
> unsigned integer)
> SUBDATASET_37_NAME=HDF4_EOS:EOS_GRID:"MISR_AM1_AS_LAND_P174_O001092_F07_0022.b117-118.hdf":SubregParamsLnd:LAIMean2
> SUBDATASET_37_DESC=[180x128x512x6] LAIMean2 SubregParamsLnd (8-bit
> unsigned integer)
> SUBDATASET_38_NAME=HDF4_EOS:EOS_GRID:"MISR_AM1_AS_LAND_P174_O001092_F07_0022.b117-118.hdf":SubregParamsLnd:LAIDelta2
> SUBDATASET_38_DESC=[180x128x512x6] LAIDelta2 SubregParamsLnd (32-bit
> floating-point)
> SUBDATASET_39_NAME=HDF4_EOS:EOS_GRID:"MISR_AM1_AS_LAND_P174_O001092_F07_0022.b117-118.hdf":SubregParamsLnd:LAINumGoodFit2
> SUBDATASET_39_DESC=[180x128x512x6] LAINumGoodFit2 SubregParamsLnd (8-bit
> unsigned integer)
> SUBDATASET_40_NAME=HDF4_EOS:EOS_GRID:"MISR_AM1_AS_LAND_P174_O001092_F07_0022.b117-118.hdf":SubregParamsLnd:LAIQA
> SUBDATASET_40_DESC=[180x128x512x6] LAIQA SubregParamsLnd (8-bit unsigned
> integer)
> SUBDATASET_41_NAME=HDF4_EOS:EOS_GRID:"MISR_AM1_AS_LAND_P174_O001092_F07_0022.b117-118.hdf":SubregParamsLnd:SubrVar
> SUBDATASET_41_DESC=[180x128x512x4] SubrVar SubregParamsLnd (8-bit
> unsigned integer)
> Corner Coordinates:
> Upper Left ( 0.0, 0.0)
> Lower Left ( 0.0, 512.0)
> Upper Right ( 512.0, 0.0)
> Lower Right ( 512.0, 512.0)
> Center ( 256.0, 256.0)
> This message is subject to the CSIR's copyright terms and conditions,
> e-mail legal notice, and implemented Open Document Format (ODF) standard.
> The full disclaimer details can be found at
> http://www.csir.co.za/disclaimer.html.
> This message has been scanned for viruses and dangerous content by
> MailScanner,
> and is believed to be clean.
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
Best regards,
Chaitanya kumar CH.
+91-9494447584
17.2416N 80.1426E
This message is subject to the CSIR's copyright terms and conditions, e-mail legal notice, and implemented Open Document Format (ODF) standard.
The full disclaimer details can be found at http://www.csir.co.za/disclaimer.html.
This message has been scanned for viruses and dangerous content by MailScanner,
