[gdal-dev] Difference in output using gdal_translate from FWTools
shell and cmd window
Frank Broniewski
brfr at metrico.lu
Thu Dec 1 05:59:41 EST 2011
are you sure that the same libraries (proj, epsg et. al.) are available
under both cirumstances? Do you have access to proj and epsg codes in
plain cmd?
That's where I would start to investigate ...
btw. I think the osgeo4w package is more recent than the fwtools build,
so might also have a look at that one
Frank
Am 01.12.2011 11:36, schrieb Anne Brookes:
> Hello,
> When I run gdalinfo and gdal_translate commands from the FWTools Shell (on Windows) the output is different to when I run the same commands from an ordinary cmd window (or from a python script). The difference is in the PROJCS, DATUM and SPHEROID metadata.
> Here is the (correct) output from the FWTools shell command window:
> C:\Program Files\FWTools2.0.4>gdalinfo : C:\JFLOW8\testgdal\D108787.tif
> Driver: GTiff/GeoTIFF
> Files: C:\JFLOW8\testgdal\D108787.tif
> Size is 597, 597
> Coordinate System is:
> PROJCS["ETRS89 / ETRS-LAEA",
> GEOGCS["ETRS89",
> DATUM["European_Terrestrial_Reference_System_1989",
> SPHEROID["GRS 1980",6378137,298.2572221010002,
> AUTHORITY["EPSG","7019"]],
> AUTHORITY["EPSG","6258"]],
> PRIMEM["Greenwich",0],
> UNIT["degree",0.0174532925199433],
> AUTHORITY["EPSG","4258"]],
> UNIT["metre",1,
> AUTHORITY["EPSG","9001"]],
> AUTHORITY["EPSG","3035"]]
> Origin = (4039990.000000000000000,2950770.000000000000000)
> Pixel Size = (10.000000000000000,-10.000000000000000)
> Metadata:
> AREA_OR_POINT=Area
> Image Structure Metadata:
> INTERLEAVE=BAND
> Corner Coordinates:
> Upper Left ( 4039990.000, 2950770.000)
> Lower Left ( 4039990.000, 2944800.000)
> Upper Right ( 4045960.000, 2950770.000)
> Lower Right ( 4045960.000, 2944800.000)
> Center ( 4042975.000, 2947785.000)
> Band 1 Block=597x3 Type=Float32, ColorInterp=Gray
> NoData Value=-9999
> And here is the output from the cmd window :
> C:\Document and Settings\jflownw> " C:\Program Files\FWTools2.0.4\bin\gdalinfo" C:\JFLOW8\testgdal\D108787.tif
> Size is 597, 597
> PROJCS["unnamed",
> GEOGCS["ETRS89",
> DATUM["unknown",
> SPHEROID["unretrievable - using WGS84",6378137,298.257223563]],
> UNIT["degree",0.0174532925199433]],
> UNIT["metre",1,
> Metadata:
> AREA_OR_POINT=Area
> INTERLEAVE=BAND
> Corner Coordinates:
> NoData Value=-9999
> Please can anyone tell me why this is happening and what I need to do to be able to get the full DATUM and SPHEROID metadata when running the GDAL commands from outside of the FWTools shell, eg. from a python script or another cmd window?
> I have been puzzling over this for a while and it is now becoming quite urgent.
> Thanks
> Anne Brookes
> Senior Analyst
> [cid:imagea52157.png at 0b641363.58fb4337]<http://www.jbaconsulting.com/>
> South Barn
> Broughton Hall
> Skipton
> North Yorkshire
> BD23 3AE
> T: +44 (0)1756 799919 F: 0845 8627772
> The JBA Family
> [cid:imageb7288b.png at 04236f77.d2b04ae4]<http://www.jbagroup.co.uk/> [cid:image840d25.png at a2776b7f.c5f34cb4]<http://www.jbarisk.com/> [cid:image98f3a8.png at fecc7dc0.dc434408]<http://www.jbaenergy.com/> [cid:image8ba6f0.png at b44205ef.33e84574]<http://www.jbatrust.org/>
> www.jbaconsulting.com<http://www.jbaconsulting.com/>
> This email is covered by JBA Consulting's email disclaimer<http://www.jbaconsulting.com/disclaimer> JBA Consulting is the trading name of Jeremy Benn Associates Limited, registered in England, company number 03246693, South Barn, Broughton Hall, Skipton, North Yorkshire, BD23 3AE.
> [cid:image836b39.png at 13d0faf1.51b34be6]<http://www.jbaconsulting.com/nce-winner-2010> [cid:imagea20f2e.png at e453a025.69b74420]<http://twitter.com/JBAConsulting>
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
Frank BRONIEWSKI
METRICO s.à r.l.
géomètres
technologies d'information géographique
rue des Romains 36
L-5433 NIEDERDONVEN
tél.: +352 26 74 94 - 28
fax.: +352 26 74 94 99
http://www.metrico.lu
