[gdal-dev] Call to users and devs - ESRI .prj files needed for
testing
Martin Daly
Martin.Daly at cadcorp.com
Fri Dec 2 11:40:17 EST 2011
> I'm not sure I understand. " one of these standard ones" refers to the
> WKT definitions by ESRI? In that case, we could compare the given WKT
> (in .prj file), and lookup the associated ESRI code, matching it to
> EPSG code.
Correct.
> Are you suggesting that we could use the GDAL definition (as derived
> from importFromEPSG()), without doing the morphFromESRI in this case?
Correct again.
Martin
Cadcorp is a trading name of Computer Aided Development Corporation Limited; registered in England;
number: 1955756. Registered office : Sterling Court, Norton Road, Stevenage, Herts SG1 2JY
This email is confidential and may be privileged and should not be used, read
or copied by anyone who is not the original intended recipient. If you have
received this email in error please inform the sender and delete it from
your mailbox or any other storage mechanism. Unless specifically stated,
nothing in this email constitutes an offer by Cadcorp and Cadcorp does not
warrant that any information contained in this email is accurate.
Cadcorp cannot accept liability for any statements made which are clearly the
sender's own and not expressly made on behalf of Cadcorp or one of its agents.
Please rely on your own virus check. No responsibility is taken by Cadcorp
for any damage arising out of any bug or virus infection.
