[gdal-dev] GDAL Ruby Bindings
Ethan Alpert
ealpert at digitalglobe.com
Fri Dec 2 16:19:36 EST 2011
Does anyone know if this made it into 1.8.1? The bug is closed but my
ruby compile with swig 2.04 is still failing.
[mailto:gdal-dev-bounces at lists.osgeo.org] On Behalf Of Jim Klassen
Sent: Thursday, March 17, 2011 8:21 AM
To: gdal-dev at lists.osgeo.org
Subject: [gdal-dev] GDAL Ruby Bindings
This message has been archived. View the original item
<https://cosev.digitalglobe.com/EnterpriseVault/ViewMessage.asp?VaultId=
1A1EA27771AEC4B4884E8701F0A6D75C11110000cosev.digitalglobe.com&SavesetId
=204000000000000~201103171421260000~1~E6D07C89FD89426CAE8E6731D75C89B>
I have updated the Ruby bindings so that they will build against Ruby
1.9 and the changes are in trunk. I am looking for people to test and
give me feedback. If it works well for people, the changes may make it
into a 1.8.x release.
Details are available at the following URLs:
http://trac.osgeo.org/gdal/wiki/GdalOgrInRuby
http://trac.osgeo.org/gdal/ticket/3999
Jim Klassen_______________________________________________
gdal-dev mailing list
http://lists.osgeo.org/mailman/listinfo/gdal-dev
This electronic communication and any attachments may contain confidential and proprietary
information of DigitalGlobe, Inc. If you are not the intended recipient, or an agent or employee
responsible for delivering this communication to the intended recipient, or if you have received
this communication in error, please do not print, copy, retransmit, disseminate or
otherwise use the information. Please indicate to the sender that you have received this
communication in error, and delete the copy you received. DigitalGlobe reserves the
right to monitor any electronic communication sent or received by its employees, agents
or representatives.
Name: not available
Type: application/ms-tnef
Desc: not available
Url : http://lists.osgeo.org/pipermail/gdal-dev/attachments/20111202/7916c739/attachment-0001.bin
