[gdal-dev] GDAL Ruby Bindings
Ethan Alpert
ealpert at digitalglobe.com
Fri Dec 2 16:35:57 EST 2011
Thanks that's what I just discovered. I applied the patches to 1.8.1 and now have successfully built ruby bindings for 1.8.1
-e
-----Original Message-----
From: Even Rouault [mailto:even.rouault at mines-paris.org]
Sent: Friday, December 02, 2011 2:31 PM
To: gdal-dev at lists.osgeo.org
Cc: Ethan Alpert; Jim Klassen
Subject: Re: [gdal-dev] GDAL Ruby Bindings
Le vendredi 02 décembre 2011 22:19:36, Ethan Alpert a écrit :
> Does anyone know if this made it into 1.8.1? The bug is closed but my
> ruby compile with swig 2.04 is still failing.
According to the comments in the ticket, this was pushed in the developement
version (1.9.0dev), but not backported in 1.8 branch.
> From: gdal-dev-bounces at lists.osgeo.org
> [mailto:gdal-dev-bounces at lists.osgeo.org] On Behalf Of Jim Klassen
> Sent: Thursday, March 17, 2011 8:21 AM
> Subject: [gdal-dev] GDAL Ruby Bindings
> This message has been archived. View the original item
> <https://cosev.digitalglobe.com/EnterpriseVault/ViewMessage.asp?VaultId=
> 1A1EA27771AEC4B4884E8701F0A6D75C11110000cosev.digitalglobe.com&SavesetId
> =204000000000000~201103171421260000~1~E6D07C89FD89426CAE8E6731D75C89B>
> I have updated the Ruby bindings so that they will build against Ruby
> 1.9 and the changes are in trunk. I am looking for people to test and
> give me feedback. If it works well for people, the changes may make it
> into a 1.8.x release.
> Details are available at the following URLs:
> http://trac.osgeo.org/gdal/wiki/GdalOgrInRuby
> http://trac.osgeo.org/gdal/ticket/3999
> Jim Klassen_______________________________________________
> gdal-dev mailing list
> This electronic communication and any attachments may contain confidential
> and proprietary information of DigitalGlobe, Inc. If you are not the
> intended recipient, or an agent or employee responsible for delivering
> this communication to the intended recipient, or if you have received this
> communication in error, please do not print, copy, retransmit, disseminate
> or otherwise use the information. Please indicate to the sender that you
> have received this communication in error, and delete the copy you
> received. DigitalGlobe reserves the right to monitor any electronic
> communication sent or received by its employees, agents or
> representatives.
This electronic communication and any attachments may contain confidential and proprietary
information of DigitalGlobe, Inc. If you are not the intended recipient, or an agent or employee
responsible for delivering this communication to the intended recipient, or if you have received
this communication in error, please do not print, copy, retransmit, disseminate or
otherwise use the information. Please indicate to the sender that you have received this
communication in error, and delete the copy you received. DigitalGlobe reserves the
right to monitor any electronic communication sent or received by its employees, agents
or representatives.
