[gdal-dev] how to combine overlapping rasters?
Brian Case
rush at winkey.org
Tue Dec 6 17:13:44 EST 2011
Etienne
you can gdal_rasterise the polys into a alpha band, then add your alpha
band to your image in a vrt.
Brian
On Tue, 2011-12-06 at 19:59 -0200, Etienne Tourigny wrote:
> A related question: How can I effectively mask (mark as nodata) raster
> pixels inside a polygon? For example, I would like to set the pixels
> of the South American map to nodata inside the political boundaries of
> Brazil, from a shapefile.
