[gdal-dev] ogr2ogr 1.9 gml3.2 output and multisurface
Gordon Tisher
GTisher at sydneyplus.com
Fri Dec 9 14:21:50 EST 2011
Thanks Even, using -nlt GEOMETRY works great for my application.
> This can be solved by 2 similar solutions. Add -nlt MULTIPOLYGON to
> your ogr2ogr command line to force conversion of simple polygons to
> multipolygons.
> Or add -nlt GEOMETRY so that the target layer is just advertized as
> being of type wkbUnknown, which will be translated as a
> gml:GeometryPropertyType in the XSD.
