[gdal-dev] Inserting into PostGIS table with primary key using ogr2ogr
Chaitanya kumar CH chaitanya.ch at gmail.com
Mon Dec 12 13:42:15 EST 2011
Sig,
Can you check if the fid column names match?
On Mon, Dec 12, 2011 at 11:25 PM, Luca Sigfrido Percich <sigfrido at tiscali.it
> wrote:
> Hi All,
> I'm using ogr2ogr to load a shapefile into an already existing empty
> PostGIS table, which has a primary key constraint on an integer column.
> All the row in the shapefile contain valid unique values for the PK
> column, but when loading the shape with
> ogr2ogr -append -update -a_srs EPSG:3003 -f 'PostgreSQL' "PG:host=$HOST
> dbname=$DATABASE user=$USER active_schema=$SCHEMA"
> "$PATH_IN_SHP/$SHP_FERMATE" -nlt Polygon  -nln t_cmi_fermate
> I get the following error:
> ERROR 1: INSERT command for new feature failed.
> ERROR:  null value in column "id_fermata" violates not-null constraint
> I also tried the --config PG_USE_COPY YES, and I get:
> ERROR 1: COPY statement failed.
> I figured out that when ogr2ogr/PG finds a primary key, it assumes that
> it is an autoinc or serial column and does not provide the values from
> the source dataset for the INSERT or COPY instruction.
> If i drop the PK constraint from PostGIS, and reissue the ogr2ogr
> command, the shape gets loaded with no errors. So a temporary workaround
> is to drop the PK constraint, load data and re-create the constraint.
> Is this the expected behaviour?
> I must add that I did the same on a SQLite/Spatialite DB, and data got
> loaded without raising this error.
> Thank you for your attention
> Sig
> _____________
> PRIVACY
> Le informazioni contenute in questo messaggio sono riservate e
> confidenziali. Il loro utilizzo e' consentito esclusivamente al
> destinatario del messaggio, per le finalità indicate nel messaggio stesso.
> Qualora Lei non fosse la persona a cui il presente messaggio è destinato,
> La invitiamo ad eliminarlo dal Suo Sistema e a distruggere le varie copie o
> stampe, dandone gentilmente comunicazione all’indirizzo mail del mittente.
> Ogni utilizzo improprio e' contrario ai principi del D.lgs 196/03 e alla
> legislazione europea (Direttiva 2002/58/CE).
> PRIVACY
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
Best regards,
Chaitanya kumar CH.
+91-9494447584
17.2416N 80.1426E
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20111213/9ddf151a/attachment.html
