[gdal-dev] Proposed patch for HUGE GML files (1)
a.furieri at lqt.it
a.furieri at lqt.it
Tue Dec 13 04:51:38 EST 2011
On Mon, 12 Dec 2011 18:15:07 +0100, Even Rouault wrote
> > Please see the attached zipfile containing the latest
> > version of the proposed patch
> Integrated in svn with a few changes. See
> http://trac.osgeo.org/gdal/ticket/4380#comment:1 for the details.
> Please test that I haven't caused regressions.
Hi Even,
thanks a lot for committing my proposed patch
into the SVN.
I've found a single regression; please see the
attached gml-regression.diff file.
Comment:
pChild->pItem->gmlText does actually contain a very
complex GML fragment (complete Edge definition),
looking more or less like this:
<Edge gml:id="Edge_35_110631">
<directedNode orientation="-">
<Node gml:id="Node_1_12918040" />
</directedNode>
<directedNode>
<Node gml:id="Node_1_12918079" />
</directedNode>
<curveProperty>
<LineString srsName="urn:ogc:def:crs:EPSG:3003">
<posList srsDimension="2">
1656238.08 4694143.96 1656260.36 4694138.56
</posList>
</LineString>
</curveProperty>
</Edge>
Using CPLCreateXMLNode(psNewNode, CXT_Text, ...)
is not at all appropriate in this case, because this
isn't GML TEXT, it's a complex GML fragment representing
a full tree of GML nodes (many different types).
Attempting to add a single GML TEXT node will simply
cause heavy GML corruption, because any "<" will
be masked as "<" and so on ...
by Sandro
Type: application/x-zip-compressed
Desc: not available
Url : http://lists.osgeo.org/pipermail/gdal-dev/attachments/20111213/cb189951/gml-regression.bin
