[gdal-dev] Which is the way to handle altitude layers within one
file?
Andreas H.
lists at hilboll.de
Wed Dec 14 07:37:30 EST 2011
the subject basically says it. What would be the way to go if I want to
store multiple altitude layers within a file? The grid contains 64
latitudes, 128 longitudes, and 60 altitude levels. How do I need to create
the file in order to be able to use tools like gdalwarp to modify the
data/grid?
thanks for your insight,
Andreas.
