[gdal-dev] Re: Runtime error on executing "OGRRegisterAll()" function.
mrym meryemvrl at gmail.com
Thu Dec 15 06:49:49 EST 2011
This has started happening to me also. When i call any function from gdal
library i get this error:
"Unhandled exception at 0x7264082a (msvcr90d.dll) in test.exe: 0xC0000005:
Access violation reading location 0x6973762f."
Error happens at iosfwd file at this function
    static int __CLRCALL_OR_CDECL compare(_In_count_(_Count) const _Elem
*_First1, _In_count_(_Count)
    const _Elem *_First2, size_t _Count){
        	// compare [_First1, _First1 + _Count) with [_First2, ...)
                //  _DEBUG_POINTER(_First1);
                //  _DEBUG_POINTER(_First2);
	        return (::memcmp(_First1, _First2, _Count));
<----------------i get error at this line
I also built gdal with /MDd option but i still get this error. Any help will
be appreciated. Thanks in advance..
View this message in context: http://osgeo-org.1803224.n2.nabble.com/Runtime-error-on-executing-OGRRegisterAll-function-tp4453903p7096855.html
Sent from the GDAL - Dev mailing list archive at Nabble.com.
