[gdal-dev] Re: Runtime error on executing "OGRRegisterAll()" function.
mrym meryemvrl at gmail.com
Thu Dec 15 10:33:02 EST 2011
Here is my command line:
/Od /I "E:\BELGIS\gdal-1.7.2\libecwj2-3.3\Source\include" /I
"C:\mrym\warmerda\bld\include" /D "WIN32" /D "_DEBUG" /D "_WINDOWS" /D
"_USRDLL" /D "BELGDAL_EXPORTS" /D "_WINDLL" /D "_UNICODE" /D "UNICODE" /Gm
/EHsc /RTC1 /MDd /Fo"Debug\\" /Fd"Debug\vc90.pdb" /W3 /nologo /c /ZI /Gd /TP
/errorReport:prompt
*Here is my test code:*
   #include <iostream>
   #include <windows.h>
   #include <tchar.h>
   typedef void (*ProjectPointCall)();
   int main(){
      set_PGdal_ProjType_In _set_PGdal_ProjType_In;
      set_PGdal_ProjType_Out _set_PGdal_ProjType_Out;
      ProjectPointCall _ProjectPointCall;
      HINSTANCE hInstLibrary = LoadLibrary(_T("belGdal.dll"));
      if (hInstLibrary){
	  _ProjectPointCall=(ProjectPointCall)GetProcAddress(hInstLibrary,
"ProjectPointCall");
	  _ProjectPointCall();
	  FreeLibrary(hInstLibrary);
      else{
        std::cout << "DLL Failed To Load!" << std::endl;
      return 0;
*This is _ProjectPointCall():*
   void __cdecl ProjectPointCall(){
	double *aXOut= new double;
	double *aYOut= new double;
        Gdal_ProjectPoint( 0.0,  0.0, p_ProjType_In, p_ProjType_Out,  aXOut,
aYOut );
*p_ProjType_In, p_ProjType_Out are static variables.
This is Gdal_ProjectPoint function:*
   bool __stdcall Gdal_ProjectPoint(double aXIn, double aYIn, const
PGdal_ProjType aProjIn, const
   PGdal_ProjType  aProjOut, double* aXOut, double* aYOut ){
       bool changeProjSrc, changeProjDest;
       int datumCount = g_EPSGDatums.GetSize();
       GDALAllRegister();
       if(datumCount == 0)
          SetupEPSGDatums();
When i debug it i get error at  GDALAllRegister(). I've tried debugging
other functions in my dll and all gdal function calls gave me the same
error.
And i have changed flags and built it in this way
   nmake -f makefile.vc clean
   nmake -f makefile.vc MSVC_VER=1500 DEBUG=1
   nmake /f makefile.vc install
   nmake /f makefile.vc devinstall
Thanks a lot..
View this message in context: http://osgeo-org.1803224.n2.nabble.com/Runtime-error-on-executing-OGRRegisterAll-function-tp4453903p7097491.html
Sent from the GDAL - Dev mailing list archive at Nabble.com.
