[gdal-dev] OGR PG Driver 1.8 to 1.9 undocumented functionality
	change (bug?) with ExecuteSQL/GetSpatialRef
    Even Rouault
    even.rouault at mines-paris.org
    Fri Dec 16 07:40:28 EST 2011
Selon Silas Parker <skyhisi at gmail.com>:
> Hello,
> I've found that the behaviour of the PG (Postgres/Postgis) driver has
> changed between 1.8 and 1.9 in ExecuteSQL that isn't listed in the
> NEWS file.
> The Spatial reference system of a SQL query can not be obtained (using
> GetSpatialRef) if the SQL query starts with white-space.
> This may be a bug, or an undocumented change in functionality!
At first sight, it would look rather to be a bug than a desired change. Could
you test if the following works with 1.8.0 and svn head ?
ogrinfo -ro -so -sql "PG:dbname=geocoder user=postgres password=postgres"
codepoint works
It could be also usefull if you could attach the result of those commands with
"--debug on" added on the command line.
> I am testing with trunk SVN rev 23573, on Ubuntu 10.04.
> The problem can be reproduced using ogrinfo, although I first observed
> this in a different application.
> In version 1.8.0:
> $ ogrinfo --version
> GDAL 1.8.0, released 2011/01/12
> $ ogrinfo -ro -so -sql " SELECT * FROM codepoint" "PG:dbname=geocoder
> INFO: Open of `PG:dbname=geocoder user=postgres password=postgres'
>       using driver `PostgreSQL' successful.
> Layer name: sql_statement
> Geometry: Unknown (any)
> Feature Count: 1689582
> Extent: (63215.000000, 8195.000000) - (655448.000000, 1213660.000000)
> Layer SRS WKT:
> PROJCS["OSGB 1936 / British National Grid",
>     GEOGCS["OSGB 1936",
>         DATUM["OSGB_1936",
>             SPHEROID["Airy 1830",6377563.396,299.3249646,
>                 AUTHORITY["EPSG","7001"]],
>             AUTHORITY["EPSG","6277"]],
>         PRIMEM["Greenwich",0,
>             AUTHORITY["EPSG","8901"]],
>         UNIT["degree",0.01745329251994328,
>             AUTHORITY["EPSG","9122"]],
>         AUTHORITY["EPSG","4277"]],
>     UNIT["metre",1,
>         AUTHORITY["EPSG","9001"]],
>     PROJECTION["Transverse_Mercator"],
>     PARAMETER["latitude_of_origin",49],
>     PARAMETER["central_meridian",-2],
>     PARAMETER["scale_factor",0.9996012717],
>     PARAMETER["false_easting",400000],
>     PARAMETER["false_northing",-100000],
>     AUTHORITY["EPSG","27700"],
>     AXIS["Easting",EAST],
>     AXIS["Northing",NORTH]]
> FID Column = ogc_fid
> Geometry Column = wkb_geometry
> postcode: String (0.0)
> countryc: String (0.0)
> countyc: String (0.0)
> districtc: String (0.0)
> wardc: String (0.0)
> nhsregionc: String (0.0)
> nhsareac: String (0.0)
> countrys: String (0.0)
> countys: String (0.0)
> districts: String (0.0)
> wards: String (0.0)
> nhsregions: String (0.0)
> nhsareas: String (0.0)
> In version 1.9:
> $ ogrinfo --version
> GDAL 1.9dev, released 2011/01/18
> Layer SRS WKT:
> (unknown)
> wardc: String (0.0)
> wards: String (0.0)
> Thanks,
> Silas
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
