[gdal-dev] Re: error by starting gdal_merge.bat (win7,
fwtools 2.4.7)
Chaitanya kumar CH
chaitanya.ch at gmail.com
Mon Dec 19 08:40:06 EST 2011
Jan,
That package contains minimalist executables. It does not contain the
pythin scripts. Use OSGeo4W to install it.
On Mon, Dec 19, 2011 at 6:44 PM, Jan Tappenbeck <osm at tappenbeck.net> wrote:
> HI !
> i download http://download.osgeo.org/**gdal/win32/1.6/**
> gdalwin32exe160.zip<http://download.osgeo.org/gdal/win32/1.6/gdalwin32exe160.zip>- but i did not found gdal_merge here ?
> is this the wrong package ?
> regards Jan :-)
> Am 28.11.2011 18:53, schrieb Chaitanya kumar CH:
>> Jan,
>> A problem like this could be caused by any number of reasons.
>> FWTools-2.4.7 for windows is pretty outdated. It's better to uninstall
>> it and use the binaries from OSGeo4W [1].
>> See if the error is resolved when using it.
>> [1]: http://trac.osgeo.org/gdal/**wiki/DownloadingGdalBinaries#**OSGeo4W<http://trac.osgeo.org/gdal/wiki/DownloadingGdalBinaries#OSGeo4W>
>> On Mon, Nov 28, 2011 at 9:25 PM, Jan Tappenbeck <tappenbeck at widemann.de
>> <mailto:tappenbeck at widemann.de**>> wrote:
>> Hi !
>> i try to start a gdal_merge by win7 64 bit and the fwtools 2.4.7
>> gdal_merge.bat -ul_lr 2601660.7343 5477349.8203 2607572.5742
>> 5475273.3574 -of GTiff -o %output%_number.tif %input%
>> but i get the message
>> C:\Program Files (x86)\FWTools2.4.7>echo off
>> Traceback (most recent call last):
>> File "C:\PROGRA~2\FWTOOL~1.7\bin\__**gdal_merge.py", line 463, in ?
>> sys.exit(main())
>> File "C:\PROGRA~2\FWTOOL~1.7\bin\__**gdal_merge.py", line 433, in
>> main
>> if quiet == 0 and verbose == 0:
>> UnboundLocalError: local variable 'quiet' referenced before assignment
>> could everyone tell me the reason for this message ?
>> reagards Jan :-)
>> ______________________________**___________________
>> gdal-dev mailing list
>> gdal-dev at lists.osgeo.org <mailto:gdal-dev at lists.osgeo.**org<gdal-dev at lists.osgeo.org>
>> http://lists.osgeo.org/__**mailman/listinfo/gdal-dev<http://lists.osgeo.org/__mailman/listinfo/gdal-dev>
>> <http://lists.osgeo.org/**mailman/listinfo/gdal-dev<http://lists.osgeo.org/mailman/listinfo/gdal-dev>
>> Best regards,
>> Chaitanya kumar CH.
>> +91-9494447584
>> 17.2416N 80.1426E
Best regards,
Chaitanya kumar CH.
+91-9494447584
17.2416N 80.1426E
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20111219/a1fdec66/attachment.html
