[gdal-dev] How to-- gdal_calc.py
Stephen Mather mather.stephen at gmail.com
Tue Dec 20 12:25:35 EST 2011
Thanks Travis,
Steve
On Tue, Dec 20, 2011 at 10:24 AM, Travis Kirstine
<traviskirstine at gmail.com>wrote:
> Stephen,
> I haven't used the gdal_calc tool but if you use python you can easily
> convert the image bands to a set of numpy arrays and use all the
> great numpy functions.
> See the val_repl.py  sample to convert a image to a numpy array(s)
> http://svn.osgeo.org/gdal/trunk/gdal/swig/python/samples/val_repl.py
> Numpy Stuff:
> http://www.scipy.org/Numpy_Example_List#head-7eb5ca476fca411db1db64bc024b7c0c94e42143
> Regards
> On 20 December 2011 10:11, Stephen Mather <mather.stephen at gmail.com>
> wrote:
> > Hi All,
> >       Is there any casting (for lack of a better word) needed when using
> > gdal_calc to take, e.g. a series of 16-bit images and perform float
> > functions against them?
> > Best,
> > Steve
> > gdal-dev mailing list
> > gdal-dev at lists.osgeo.org
> > http://lists.osgeo.org/mailman/listinfo/gdal-dev
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20111220/0c9e1c03/attachment.html
