Re : [gdal-dev] GDAL interpolation of Gtiff / ESRI polygon.shp
Yves Jacolin yjacolin at free.fr
Wed Dec 21 06:34:10 EST 2011
Hello,
Ogrinfo is for vector files, use gdalinfo instead.
Regards,
Yves Jacolin
----- Reply message -----
De : "RolandB" <rbaatz at gmail.com>
Pour : <gdal-dev at lists.osgeo.org>
Objet : [gdal-dev] GDAL interpolation of Gtiff / ESRI polygon.shp
Date : mer., déc. 21, 2011 12:13
Dear users,
I want use gdal for some file transformation.
Any help in solving the issue is greatly appreciated by me! It would
be great if one of you have solved already this problem or knows how to do
so.
By gdal_rasterize I did create a Gtiff raster from a ESRI Polygon shapefile.
This is successful. I have worked with the Gtiff successful later on with
$user>: gdal_translate -of netCDF ./tmp/output.tif ./tmp/output2.nc
Still some commands do not work. I'm looking forward for replies.
Where is the GTiff driver in the list below???
And what is the output layer of the Gtiff file? I tried "1", "Band1",
"band". No file opening with any band.
So here are the commands and the error messages:
First:
*$user>: * gdal_rasterize -a kennummer -init 0 -l Bk50_rur_wgs -te 5.93
50.39 6.74722 51.22886 -ts 59 94 -ot Int32 ./Input/bk50_rur_wgs.shp
./tmp/output.tif
0...10...20...30...40...50...60...70...80...90...100 - done.
*$user>: *gdal_grid -a invdist:power=2.0:smoothing=1.0 -ot Int32 -txe
50.39 51.22886 -tye 5.93 6.74722 -outsize 59 94 -l Band1
./tmp/output.tif ./tmp/newout.tif
Unable to open input datasource "./tmp/output.tif".
*$user>:* "gdalinfo ./tmp/output.tif"
Driver: GTiff/GeoTIFF
Files: ./tmp/output.tif
Size is 59, 94
Coordinate System is:
GEOGCS["WGS 84",
  DATUM["WGS_1984",
      SPHEROID["WGS 84",6378137,298.257223563,
          AUTHORITY["EPSG","7030"]],
      AUTHORITY["EPSG","6326"]],
  PRIMEM["Greenwich",0],
  UNIT["degree",0.0174532925199433],
  AUTHORITY["EPSG","4326"]]
Origin = (5.930000000000000,51.228859999999997)
Pixel Size = (0.013851186440678,-0.008924042553191)
Metadata:
 AREA_OR_POINT=Area
Image Structure Metadata:
 INTERLEAVE=BAND
Corner Coordinates:
Upper Left  (   5.9300000,  51.2288600)
Lower Left  (   5.9300000,  50.3900000)
Upper Right (   6.7472200,  51.2288600)
Lower Right (   6.7472200,  50.3900000)
Center      (   6.3386100,  50.8094300)
Band 1 Block=59x34 Type=Int32, ColorInterp=Gray
*$user>: *"ogrinfo ./tmp/output.tif"
FAILURE:
Unable to open datasource `./tmp/output.tif' with the following drivers.
 -> ESRI Shapefile
 -> MapInfo File
 -> UK .NTF
 -> SDTS
 -> TIGER
 -> S57
 -> DGN
 -> VRT
 -> REC
 -> Memory
 -> BNA
 -> CSV
 -> GML
 -> GPX
 -> KML
 -> GeoJSON
 -> GMT
 -> SQLite
 -> PostgreSQL
 -> PCIDSK
 -> XPlane
 -> AVCBin
 -> AVCE00
 -> DXF
 -> Geoconcept
 -> GeoRSS
 -> GPSTrackMaker
 -> VFK
 -> PGDump
 -> GPSBabel
 -> SUA
 -> OpenAir
 -> PDS
 -> WFS
 -> HTF
 -> AeronavFAA
*$user>:* gdal_translate -of netCDF ./tmp/output.tif ./tmp/output2.nc
Input file size is 59, 94
(This last should be done with the interpolated file, which I did not
manage so far.)
Best regards,
Roland
View this message in context: http://osgeo-org.1803224.n2.nabble.com/GDAL-interpolation-of-Gtiff-ESRI-polygon-shp-tp7114807p7114807.html
Sent from the GDAL - Dev mailing list archive at Nabble.com.
gdal-dev mailing list
http://lists.osgeo.org/mailman/listinfo/gdal-dev
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20111221/6a1bd6d7/attachment.html
