[gdal-dev] Gdalwarp -crop_to_cutline results in shifted raster
Marius Jigmond mariusjigmond at hotmail.com
Tue Feb 1 13:40:03 EST 2011
Submitted as ticket# 3947 but I had to link the sample data because of size.
-marius
Date: Tue, 1 Feb 2011 19:00:13 +0530
Subject: Re: [gdal-dev] Gdalwarp -crop_to_cutline results in shifted raster
To: mariusjigmond at hotmail.com
CC: gdal-dev at lists.osgeo.org
Marius,
Can you provide some sample data to investigate this? You can raise a ticket at http://trac.osgeo.org/gdal/newticket and attach the data.
On Tue, Feb 1, 2011 at 8:12 AM, Marius Jigmond <mariusjigmond at hotmail.com> wrote:
Hi Everyone,
I am using the -crop_to_cutline option of gdalwarp but the resulting
raster is slightly shifted. Both cutline shapefile and raster are using
the same projection. On the sample raster dataset (pixel=28.5m) the
shift is about 5m to the east and 3.5m to the north. Pixel values remain
the same (so resampling doesn't take place, as expected).
I should add that not adding -crop_to_cutline results in no shift.
Commands I ran:
(1) gdalwarp -cutline mask.shp -crop_to_cutline sample.tif cropped.tif
result is shifted
(2) gdalwarp -cutline mask.shp sample.tif out.tif
result is not shifted
A workaround would be using gdal_rasterize on after option (2) above.
-marius
gdal-dev mailing list
http://lists.osgeo.org/mailman/listinfo/gdal-dev
Best regards,
Chaitanya kumar CH.
/tʃaɪθənjə/ /kʊmɑr/
+91-9494447584
17.2416N 80.1426E
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20110201/3faed27e/attachment.html
