[gdal-dev] Re: gdal_rasterize 1.8.0 options
Marius Jigmond
mariusjigmond at hotmail.com
Sat Feb 5 10:35:36 EST 2011
Even,
Hermann might be right. From reading several sources:
http://gge.unb.ca/Pubs/TR46.pdf
http://www.manifold.net/doc/double_stereographic.htm
it seems that double stereographic is oblique stereographic as long as
the origin is non-equatorial or non-polar.
The actual denomination "Double Stereographic" seems to be a ESRI
by-product that refers to "Oblique Stereographic". However, ESRI's own
descriptions of these projections are, at best, vague.
-marius
On Sat, 2011-02-05 at 13:12 +0100, Even Rouault wrote:
> Le samedi 05 février 2011 12:49:15, Hermann Peifer a écrit :
> > On 05/02/2011 00:06, Even Rouault wrote:
> > > Unrelated with GDAL 1.8.0. The issue was that the transformation between
> > > OGC WKT and ESRI WKT didn't handle well the Oblique Stereographic
> > > projection. Fixed in trunk in http://trac.osgeo.org/gdal/changeset/21627
> > Even,
> > Once upon a time I opened http://trac.osgeo.org/gdal/ticket/2869,
> > thinking that the reported issue could be fixed with a simple remapping
> > between Double_Stereographic and Oblique_Stereographic projections.
> > Could you perhaps have a look at this 2-year old ticket?
> > Thanks in advance, Hermann
> Hermann,
> I've just had a look, but not being neither Dutch nor a specialist of
> (stereographic) projections, I don't feel competent enough to do any action on
> it. Those tickets plus the reading of
> http://udig.refractions.net/files/docs/api-
> geotools/org/geotools/referencing/operation/projection/Stereographic.html make
> me deeply confused and wondering if r21627 was really appropriate.
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
