[gdal-dev] error adding ecw on Ubuntu 10.4 (lucid)
Matt Wilkie maphew at gmail.com
Sun Feb 6 13:00:03 EST 2011
> Check that the gdal_ECW.so (or whatever is name is) is installed in the GDAL
> plugin directory and then do a ldd on this .so to see if the ECW SDK .so are
> reachable. You might need to adjust the /etc/ld.so.conf or LD_LIBRARY_PATH to
> add them.
Is this searchable: ?
matt at ubuntu-desktop:~$ locate ECW.so
/usr/lib/gdal17plugins/gdal_ECW_JP2ECW.so
matt at ubuntu-desktop:~$ ldd /usr/lib/gdal17plugins/gdal_ECW_JP2ECW.so
	linux-vdso.so.1 =>  (0x00007ffff1d96000)
	libNCSEcw.so.0 => /usr/local/lib/libNCSEcw.so.0 (0x00007fbc071aa000)
	libNCSCnet.so.0 => /usr/local/lib/libNCSCnet.so.0 (0x00007fbc06f94000)
	libNCSUtil.so.0 => /usr/local/lib/libNCSUtil.so.0 (0x00007fbc06d6d000)
	libgdal.so.1 => /usr/local/lib/libgdal.so.1 (0x00007fbc06443000)
	libstdc++.so.6 => /usr/lib/libstdc++.so.6 (0x00007fbc0612f000)
	libm.so.6 => /lib/libm.so.6 (0x00007fbc05eab000)
	libgcc_s.so.1 => /lib/libgcc_s.so.1 (0x00007fbc05c94000)
	libc.so.6 => /lib/libc.so.6 (0x00007fbc05912000)
	libdl.so.2 => /lib/libdl.so.2 (0x00007fbc0570d000)
	librt.so.1 => /lib/librt.so.1 (0x00007fbc05505000)
	libsqlite3.so.0 => /usr/lib/libsqlite3.so.0 (0x00007fbc05278000)
	libpthread.so.0 => /lib/libpthread.so.0 (0x00007fbc0505a000)
	libexpat.so.1 => /lib/libexpat.so.1 (0x00007fbc04e31000)
	libjasper.so.1 => /usr/lib/libjasper.so.1 (0x00007fbc04bda000)
	libgif.so.4 => /usr/lib/libgif.so.4 (0x00007fbc049d0000)
	libjpeg.so.62 => /usr/lib/libjpeg.so.62 (0x00007fbc047ac000)
	libpng12.so.0 => /lib/libpng12.so.0 (0x00007fbc04585000)
	libpq.so.5 => /usr/lib/libpq.so.5 (0x00007fbc0435c000)
	libz.so.1 => /lib/libz.so.1 (0x00007fbc04145000)
	/lib64/ld-linux-x86-64.so.2 (0x00007fbc0772a000)
	libssl.so.0.9.8 => /lib/libssl.so.0.9.8 (0x00007fbc03ef4000)
	libcrypto.so.0.9.8 => /lib/libcrypto.so.0.9.8 (0x00007fbc03b64000)
	libkrb5.so.3 => /usr/lib/libkrb5.so.3 (0x00007fbc038a0000)
	libcom_err.so.2 => /lib/libcom_err.so.2 (0x00007fbc0369b000)
	libgssapi_krb5.so.2 => /usr/lib/libgssapi_krb5.so.2 (0x00007fbc03467000)
	libcrypt.so.1 => /lib/libcrypt.so.1 (0x00007fbc0322e000)
	libldap_r-2.4.so.2 => /usr/lib/libldap_r-2.4.so.2 (0x00007fbc02fe1000)
	libk5crypto.so.3 => /usr/lib/libk5crypto.so.3 (0x00007fbc02dbb000)
	libkrb5support.so.0 => /usr/lib/libkrb5support.so.0 (0x00007fbc02bb3000)
	libkeyutils.so.1 => /lib/libkeyutils.so.1 (0x00007fbc029af000)
	libresolv.so.2 => /lib/libresolv.so.2 (0x00007fbc02796000)
	liblber-2.4.so.2 => /usr/lib/liblber-2.4.so.2 (0x00007fbc02588000)
	libsasl2.so.2 => /usr/lib/libsasl2.so.2 (0x00007fbc0236d000)
	libgnutls.so.26 => /usr/lib/libgnutls.so.26 (0x00007fbc020cb000)
	libtasn1.so.3 => /usr/lib/libtasn1.so.3 (0x00007fbc01eb9000)
	libgcrypt.so.11 => /lib/libgcrypt.so.11 (0x00007fbc01c41000)
	libgpg-error.so.0 => /lib/libgpg-error.so.0 (0x00007fbc01a3d000)
matt at ubuntu-desktop:~$ gdalinfo --formats|grep -i ecw
-matt
